wire conector color code o2 censor
Old Nov 11, 2012 | 01:05 AM
Wally Griff's Avatar
Unhappy wire conector color code o2 censor
please help!!!!!!!!
i was replacing the primary o2 censor in my Honda city 2003 and i troy to pull out the connector and the wire slide out of it i don't know the color code for the wire to be plug in to the connector,,,,,,,please i need a pic of connector
from the harness to see how it connect to it .
Old Nov 11, 2012 | 03:23 PM
Triskelion's Avatar
Originally Posted by Wally Griff
please help!!!!!!!!
You may be the only person on these forums who owns an '03 City- this is a Honda Fit forums web site. Almost all of the members are North Americans who could only buy a Honda Fit for the first time in 2006 and bought the 2007 model, or bought later Fit models through the years............
If the "wire" that you pulled out of your 02 sensor has two leads and you can't tell which lead goes into which socket on the connector, just plug them both into the sockets and try to start the car. If it won't start, or does start and runs horribly, shut the engine off and connect the leads into the opposite connector sockets. If it starts easily and runs fine, you got it right. I am only guessing here because I don't own your car, and can't see your wires or sensor connector. There may be an on-line service manual for your car that might have a wiring diagram for your 02 sensor circuit. If there is, I am not aware of it because again, this is a Honda Fit forum. Good luck to you, and you will find that using a little logic and problem solving will help in your car care. Good luck to you!
Old Nov 11, 2012 | 04:17 PM
bro my car it has a ids-i 1.3 engine like some Honda fit,,,but here is the wire
Old Nov 11, 2012 | 05:40 PM
Triskelion's Avatar
Hey Wally, there is no photo in your post, and our GD3 and GE8 Fits are bound to be different than the wiring harness in your City. You really need to try to find either a repair manual to bring home, or find one on-line to find out where the wires should be properly hooked up. Being a resident of Jamaica (sorry that I wrote Haiti in my PM reply) is probably going to increase the difficulty in finding a photo or repair instructions for your wiring harness.
LilPuttputt
Fit I.C.E.
Nov 15, 2019 07:36 PM
skoorbryan
Mar 17, 2017 07:57 PM
tomwilley
Jan 9, 2015 08:31 PM
ekimox
Dec 17, 2013 07:53 PM
fitster
Oct 22, 2008 08:56 PM
