2013 Fit LX plastic wheel cover removal
Old Nov 15, 2012 | 12:24 PM
wing0's Avatar
Since one of the wheel cover was damaged upon delivery.
We will be getting a swap of wheel cover. The dealership is quite far so I only wanted to swap wheel cover in person instead of bringing the car in.
This is the canadian Fit LX with the plastic wheel cover.
I've taken wheel covers off before on other makes, but somehow this wheel cover just won't budge around the hubcap area. Instructions from the manual just says to pull, well I lifted the cover off the entire rim edges, but still can't get it off.
Does anyone know if the wheel cover is held on by the lug nuts?
There is a metal like bracket on the inside of the wheel cover hubcap area.
Thanks.
Old Nov 15, 2012 | 12:29 PM
Hootie's Avatar
I don't recall doing a tire rotation in a newer Fit Base for a while... I honestly believe that the wheel covers are indeed held in place by the lug nuts. Check for a light gray or black plastic clip that rides around the perimeter of lug nuts. If it has that, the lug nuts should have to come off.
Old Nov 15, 2012 | 12:35 PM
wing0's Avatar
Yes, I think I saw a black plastic o-ring that rides around the lug nuts.
The manual said to take the cover off before unscrewing the lug nuts...weird...
Old Nov 16, 2012 | 01:54 AM
wing0's Avatar
Anybody else have first hand experience with taking off the wheel cover?
Old Nov 16, 2012 | 04:50 AM
Black3sr's Avatar
I recall trying to pull some covers off my old Stratus. Finally realized needed to take lug nuts off first. So why not jack it up and take a wheel off and see what happens? It will be a nice sunny day today.
Old Nov 16, 2012 | 11:39 AM
kered424's Avatar
I have a 2012 Fit Base. I literally just pulled and the wheel covers came off. If I remember correctly, I think there are grooves on the side of the wheel covers where you can stick a flat head screwdriver in to help pry it off.
wzlfit
Jun 30, 2016 08:20 PM
fitnew
Mar 21, 2015 04:10 AM
Tk3
May 31, 2013 02:13 PM
eddie777
May 4, 2009 01:32 PM
shudderbug
Dec 23, 2007 10:14 AM
