Would 16x7 +25 work emotion kai fit gd3?
Old Nov 19, 2012 | 10:31 AM
kaytsu's Avatar
As the title says does 16x7 +25 fit a gd3 fit? Also which tyres should i get with these sizes? Car will be on stock height. I did abit of research, should i go 205/50/16? or should go 195/55 or 50/16? the profile of tyre is my main concern.
Old Nov 19, 2012 | 02:14 PM
dj_konix's Avatar
Yes they will fit, issue you will have is the rims is quite thin for the offset so getting a tyre to fit and not scrub might be an issue. I know of a few aussie guys that have used 195/50/16 but i would go same as myself and run 195/46r16
Old Nov 22, 2012 | 11:03 AM
kaytsu's Avatar
Just seen your build thread, a nice car you have there. I noticed that you had to run spacers at the back to clear that control arm. You have 16x8.5s? and the wheels touched that arm? with my offset you think i will have that problem?
Old Nov 22, 2012 | 03:25 PM
dj_konix's Avatar
Cheers, it's getting there as for the reason i run spacers, it has alot to do with the offset of my wheels before widening them. Stickers said +38 but were actually +48 and that's not good, i minus'd 6mm off when i added the extra half inch and then it's +42. Still to tucked in and will always hit the inner arm.
Once spacer went on, it changed to +22 which is perfect, tonnes of room to play with. Your answer is...+25 will never hit your inner arm as you have 1.5" less of wheel and much more space to play with good luck and can't wait to see pics
GE8Anderson
Aug 6, 2020 10:11 AM
thebluepotato
29
May 3, 2010 11:14 AM
AtticusFit
Jun 21, 2008 12:55 AM
trancedsailor
Jun 18, 2008 07:16 PM
pastafarian
Nov 26, 2007 06:35 PM
