2010 Fit Misfire and IAT code
Old Dec 11, 2012 | 02:21 PM
shane's Avatar
Car has close to 40k on it now and today when I started the car up cold the CEL started flashing then stayed on steady. I've noticed over the last few weeks a rougher idle than usual but didn't think much to it since alot of Honda seem to have a shake at idle. I had the code pulled and came up with all the cylinders misfiring and random, also had a IAT code. Is this common on these cars for lower miles?
Just trying to get some info before i take it in under my extended Honda certified warranty.
Thanks!
Old Dec 11, 2012 | 03:43 PM
Goobers's Avatar
Thanks!
Is it common? I don't pay nearly enough attention, so I don't know for sure. But, I'm leaning towards no.
I have a 2010 Fit with about 54k miles on it. And the only time I got a CEL was around this time last year. I had installed a new radio and played with it until the battery died around thanksgiving. Then I went on a month long trip out of the country and the battery died again (left a few days after the install). This times I got the CEL, which I believe was related to the dead battery.
maybe you need some new spark plugs? or coil packs? I dunno.
Old Dec 11, 2012 | 03:54 PM
JaStonE's Avatar
i had this same problem. i just changed the mass air filter for about 150 bucks and problem was solved
Old Dec 11, 2012 | 04:06 PM
shane's Avatar
Yea i went ahead and put the stock intake back on the car and put the extra MAF i had laying around on it from my 2009 Fit(long story short my last fit got totaled and i took the CAI off that with the maf and installed it on my new fit when i got my 2010, so i have 2 MAFs and 2 stock intakes)
But yea the cai has been on this car for over 25k and no issues until just now with the CEL popped up.
I guess in the mean time while i have the CAI off ill clean the MAF i took off and reinstall it later.
Old Dec 14, 2012 | 06:58 PM
shane's Avatar
Well cleaned the MAF and installed and new filter on the CAI, and cleared the codes. Seems to be good so far.
Old Dec 14, 2012 | 07:10 PM
Junior Pena's Avatar
so to clear thing up, the problem was just a dirty after market filter?
Old Dec 14, 2012 | 08:02 PM
shane's Avatar
Yea i have a few buddies who are techs at Honda dealers and when i told them what's going on they asked me two things 1. how dirty is the Air filter 2. is the Maf dirty.
Honestly my Honda is just a beater/DD and i change the oil and put gas in it, it has prob been 10-15k since i last cleaned the K&N filter on my PRM CAI.
Pulled it all off and the filter was pretty nasty so i cleaned the MAF and got a brand new filter for it and the idle and driving seems to be a little smoother, and no Check engine light either.
Old Dec 15, 2012 | 10:09 AM
Steve244's Avatar
the problem was an aftermarket CAI/Air filter that got crap on the MAF sensor and/or had the wrong cross sectional diameter (air flow was measured wrong).
A dirty air filter will not cause misfires, loss of efficiency in a fuel injected car. If it's plugged there will be some loss in power.
FITDragon
Nov 11, 2021 09:08 PM
Nussjohnathan@gmail.com
Nov 23, 2020 09:03 PM
Gula
Feb 22, 2017 12:52 PM
madvibes
Aug 31, 2010 07:16 PM
Steve
May 4, 2005 11:16 AM
