Independent GE8 Fogs
Old Dec 17, 2012 | 07:42 PM
BlueBoogers's Avatar
Do I need to bend a 5-pin relay's pin or what?
I want to keep fogs on when I go to high-beams, that's all. If someone knows where the fog relay is, I can do a pin out and bend the pin that shuts the relay out of the way.
Old Dec 18, 2012 | 08:15 AM
x4x5x1x's Avatar
Best I could find for ya..
Old Dec 18, 2012 | 08:27 AM
WTF how is it not a 5-pin relay. I must not have enough of a grasp on electronics.
Old Dec 18, 2012 | 09:05 AM
x4x5x1x's Avatar
Outside of positive and negative I don't have much of a grasp on it at all. Good luck man ha.
Old Dec 18, 2012 | 09:21 AM
FitStir's Avatar
Most of the pics/DIY is down, but there was a DIY on here a while ago where all you did was use 1 wire to tap into 2 different locations, and it worked, with or without headlights and/or highbeams on/off. Fully independent. I did it, but it's been so long ago I'd have to check the locations again.
This is the original thread --> https://www.fitfreak.net/forums/2nd-...operation.html
you could try this one too --> https://www.fitfreak.net/forums/2nd-...foglights.html Not sure what ever happened with that route.
Old May 2, 2019 | 01:13 AM
bradbrandmeier@yahoo.com's Avatar
Saw your fuse diagram for 2009 Honda Fit where is the MG Clitch relay on this Honda Fit
AtticusFit
Jul 13, 2024 06:43 PM
kurisux92
Jul 13, 2012 05:50 PM
kupalm69
Jun 14, 2010 04:54 AM
jsnatchdiggity
Jul 17, 2008 02:40 PM
Reinert79
17
Apr 11, 2008 01:21 PM
