17x7 +40 anyone running it :)!???
Old Jan 16, 2013 | 01:59 PM
Wafulz's Avatar
hi there i wanted to go 17in rims but wanted to know how it will look and i wanna run 215/45 tires im on buddy clubs so ride height not the issue i just dnt wanna pull fenders i rather roll the inside thats all
Old Jan 16, 2013 | 09:16 PM
mahout's Avatar
I couldn't run 215/45x17 on 40mm offset tires on any Fit here. You need 45mm offset and 195/45 or 40 x17 tires.
Old Jan 16, 2013 | 09:56 PM
BlackPearlFIT's Avatar
I have 17x7 +40 with 205/40 tires on it
Old Jan 17, 2013 | 01:36 AM
DreaMv's Avatar
you might have to roll/pull/trim the fenders if you plan on going lower on the BCs but very sure they fit lol... anything can fit! even 18x9.5 +0
Old Jan 17, 2013 | 02:50 AM
FittedOnEm's Avatar
Same exact specs I ran on my Momo's. I was running -2.5 degrees of camber and had to pull the front fenders when I sat at this height:
(shameless plug - these are for sale)
Old Jan 17, 2013 | 12:25 PM
Mini_Odyssey's Avatar
Thats a pretty tight offset bro, it looks pretty darn flush.
Old Jan 17, 2013 | 12:41 PM
Wafulz's Avatar
FittedOnEm whats ur spec
Old Jan 17, 2013 | 02:15 PM
DreaMv's Avatar
read some above..
Old Jan 18, 2013 | 01:16 PM
mrphilip's Avatar
I'm bagged and running 17x7 +42 wheels with no camber or modified fenders. All wheels tuck just fine when I fully dump the car. 2mm isn't too much of a difference so I'd say you can get away with it without any fender modifications. Hope this helps!
Old Mar 5, 2013 | 09:43 AM
MugenShelly's Avatar
I'm in the process of buying wheels too. Work 17x7 +42, but I'm trying to make sure they're gunna sit flush with my fenders and no rolling needed. I've seen some say I should be fine, they some say major rolling necessary. Anyone? :\
Old Mar 5, 2013 | 05:20 PM
mahout's Avatar
I couldn't run 40mm offset on 17x7 wheels and 195/45 tires but just barely could with 195/40x17's. We had only one other who insisted on trying but couldn't either.
You're much safer wth 45mm offset.
Old Mar 6, 2013 | 08:30 PM
Badwrench's Avatar
A big part of this is that you are on coils. Since you will be able to control the amount of wheel travel (by setting more pre-load in the spring), you can set it up how you like. I would personally go with a 195/45 or 205/40 setup. On just springs, the wheels travel a bit further and rub a bit easier.
Stay_Fitted
Jul 22, 2013 09:45 AM
kam
May 17, 2013 12:32 AM
Burzpaw
Dec 9, 2011 03:20 PM
Pmpn8ez05
Oct 5, 2011 12:00 AM
cdezspykez
Jun 3, 2010 12:01 PM
