Beveled vrs rounded lug nuts and wrench size?
Old Jan 24, 2013 | 10:54 AM
doane2u's Avatar
Have a 2009 base with steel wheels. The plastic hub caps were scuffed up and I decided to leave the wheels bare so I cleaned them up and painted them. I bought a set of chrome, acorn type lug nuts with beveled edges and installed them.
The first thing I noticed was that the OEM wrench was too small to fit the chrome bolt heads and I had to use the wrench off my RAV4 to install the bolts. Is there an adapter piece I can get to keep in the tool bag with the OEM wrench, or do I have to buy a second wrench just for the new bolts?
Second thing I noticed was the nuts have a bevel instead of the rounded end.. is this going to cause any problems with the wheels?
Thanks,
Old Jan 24, 2013 | 01:44 PM
Wanderer.'s Avatar
Just go buy a wrench that fits or a tire iron? You can just put the iron under the spare with a towel and bolt the spare down so it doesn't move around while driving.
Thanks,
Yes, you need ball seat lugnuts, acorns aren't meant for factory wheels, don't use them.
Old Jan 24, 2013 | 08:54 PM
doane2u's Avatar
So, what kind of problems would there be? They seemed to tighten up fine.
Old Jan 24, 2013 | 09:33 PM
Triskelion's Avatar
Of course they "tighten up fine". But look at the ball seats in the wheel face and then look at the pointed ends of your beveled lug nuts (like the point of a pencil). Honda uses ball seats to widen the contact area of the nuts to provide the most secure contact area for the torque that holds the wheels on. Your pointed nuts will loosen from road vibration, and will be prone to stretching and elongating the wheel studs. With enough looseness and vibration, you will probably find stress cracks in the wheel faces eventually.
Old Jan 24, 2013 | 10:58 PM
doane2u's Avatar
OK, that sounds sort of logical... what are the alternatives?
I should have read this first, didn't find it the first time I looked.. (click here)
Do any of you know of a good deal on 16 ball seat acorn 12 x 1.5 chrome lug nuts?
Thanks for your help.
Old Jan 25, 2013 | 12:29 AM
Triskelion's Avatar
eBaymotors.com- type in your car, and under "parts" type in "lug nuts". Simple.
Old Jan 25, 2013 | 12:58 AM
doane2u's Avatar
I looked at the long list after searching for Honda Fit and it isn't so "simple"... they say they fit Honda Fit, but when you look you find they are conical base, not the ball type and they don't spell that out in the description, so it isn't clear. Thanks for your help though.
Old Jan 25, 2013 | 12:14 PM
Triskelion's Avatar
Just like I said, simple. This took 5 seconds to find.
2009 Honda Fit ball seat lug nuts in Car & Truck Parts | eBay
Old Jan 25, 2013 | 09:06 PM
doane2u's Avatar
Thanks Triskelion, don't know why my search didn't pull up the same thing... maybe it was too "simple" for me.
Anyway, thanks, really appreciate it.
BTW, is it a good idea to use a bit of moly grease on the threads and seat, or should they be left dry?
Old Jan 25, 2013 | 11:45 PM
Triskelion's Avatar
NOT GREASE! "Anti-Seize compound" only, and very sparingly.
Old Jan 26, 2013 | 10:05 AM
doane2u's Avatar
OK, that was a pretty emphatic response, I'll go buy some anti-seize compound. Thanks again.
Old Jan 26, 2013 | 11:07 AM
Triskelion's Avatar
Sorry, I was busy when replying- use the anti-seize on the threads only, not the lug nut seats on the wheels.
Old Jan 26, 2013 | 12:42 PM
3cg's Avatar
3cg
your torque spec changes with lubrication on the threads.
Old Jan 26, 2013 | 12:51 PM
Triskelion's Avatar
Not enough to be measured considering the variances in accuracy common to all torque wrenches.
Old Jan 26, 2013 | 08:31 PM
doane2u's Avatar
Thanks, Triskelion, I ordered the anti-seize compound and will use a bit as directed.
Old Jan 26, 2013 | 08:47 PM
Triskelion's Avatar
Glad I could help- your PM has a reply.
Old Feb 3, 2013 | 12:36 AM
copmagnet82's Avatar
...and in fact your torque will be more accurate with a little "lube" as there will be less friction between the lug and the nut, and everything will smoothly tighten up to the right torque.
Old Feb 7, 2013 | 09:10 PM
doane2u's Avatar
Question Air torque wrench?
Watch out... (video tutorial)
Old Feb 16, 2013 | 02:14 PM
Old Feb 16, 2013 | 03:53 PM
doane2u's Avatar
I can almost understand what the driver is saying...
CommanderSlug
Jan 11, 2017 08:27 AM
Press Fit
Dec 19, 2016 10:50 AM
fiteddy
Jun 26, 2013 04:59 PM
rocketberger
19
Nov 13, 2012 07:30 AM
dave92029
Sep 23, 2006 12:26 AM
