Changing the Battery
Old Feb 4, 2013 | 01:13 PM
hqly's Avatar
Any advice as to which battery to get that would fit an 07 S Fit?
First time changing a battery, any advice to avoid it beign my last time?
Plan to unscrew the bolts from battery then remove the secured panel. It should come off easily afterward right?
Old Feb 6, 2013 | 09:58 AM
jeuda's Avatar
I am changing mine too. Looking at a Bosch 38AH s4. Friends advised to start car first then remove battery to keep all setting/data intact without resetting.
Old Feb 6, 2013 | 01:24 PM
spreadhead's Avatar
Maybe on a 68 Chevelle, I wouldn'd do it on a modern car.
Old Feb 6, 2013 | 03:43 PM
Wanderer.'s Avatar
Not a good idea on a modern car with a lot of electronics. Is losing your radio settings and clock that big of a deal?
Load dump - Wikipedia, the free encyclopedia
Also danger of shorting power wire while changing battery.
To OP: should be simple, unplug neg cable first and plug neg cable back in last. Make sure you don't have battery backwards or something, not much else to it.
ChuckDustin
Mar 29, 2019 09:11 PM
fit newb
May 31, 2015 11:04 PM
pzriddle
Jan 23, 2015 06:31 PM
wenbellz
Nov 2, 2012 02:01 PM
leisuredress
Jul 10, 2010 01:49 PM
