WTB: Clutch capable of managing 200whp
Old Feb 17, 2013 | 05:17 PM
bana1988's Avatar
About to start my build and need a clutch capable of managing 200whp.need it shipped to miami,fl. 33147... kindly post iif you guys have any laying around wanting to get rid of. paypal only.
Old Feb 17, 2013 | 10:05 PM
dewthedew's Avatar
What are you running?
Old Feb 17, 2013 | 11:43 PM
DiamondStarMonsters's Avatar
Clutches are rated by torque.
Rotrex Fit making 200whp @ 6k rpm is only making 175 wtq
Small turbo Fit making that 200whp @ 5k is churning out 210 wtq
Old Feb 18, 2013 | 12:41 AM
Cocowheat's Avatar
^ what he said, buy a turbo................or was that not the point? Lol
Old Feb 19, 2013 | 09:00 PM
bana1988's Avatar
It is for a t3t4 turbo setup... Aiming for 185whp
Old Feb 19, 2013 | 09:05 PM
bana1988's Avatar
Based on what I told my mech/tuner I was aiming for they recommended I get a new clutch. However I don't see much when I google. I see some exedy claiming stages but idk what they are rated for in wtq. I guess since I'm going turbocharging I would like to know about a clutch able to manage about 250wtq I guess. Quick question, do I need to go internals for 200whp?
Old Feb 19, 2013 | 10:12 PM
Stock clutch is perfectly fine for only 185whp.. unless you get some serious tires and an LSD, with intent to drag race or launch constantly. There are more than a few making that much on a stock clutch. The trick is to not side step it frequently. Spec has a few options you can look into though.
I despise the phrase t3/t4.. what are the actual wheel and housing specs?
I'd put money down on it being a mismatched dinosaur T04 garrett compressor designed in the 1970s with a "stage III 76 trim" turbine wheel in a t31 housing or worse.. jammed into a tiny housing to give it some semblance of response at the sacrifice of everything else.
Old Feb 20, 2013 | 02:59 AM
BlueCell's Avatar
What DSM said. I run a SPEC clutch stage 3+, but you can get a lower/higher stage if you like. I like it because it feels close to stock.
Current HP 150whp/160tq
Old Feb 20, 2013 | 01:35 PM
bana1988's Avatar
I was incorrect.. its actually a gt25 .42 compressor and .49 turbine..
I am seriously now doubting my mech.
Old Feb 20, 2013 | 02:31 PM
.49? That sounds like a Nissan or 2nd gen DSM T25.. not a GT25.
Old school journal bearing model. Wonder if its a TD05H inlet flange or Garrett T25 inlet from a Nissan?
Clutch is not a bad idea, just not necessary unless you drive like a lunatic and stop light race often. At least in my opinion.
Old Feb 20, 2013 | 02:41 PM
bana1988's Avatar
i dont drive like a lunatic and im not even gonna track it soooo.. stock should be good.. ok... Thanks very much DSM
fitisbamf
Dec 15, 2009 05:56 PM
YeeFit
May 9, 2009 09:34 PM
Firebat666
Apr 24, 2008 09:38 AM
kancerr
Feb 4, 2008 01:57 PM
ride_the_pony69
Sep 10, 2007 02:36 AM
