Buddy Club N+ Coilover Review
Old Feb 21, 2013 | 01:34 PM
JDMchris.com's Avatar
I run THIS
Ok, so I had blown the struts on my previous set of coilovers, and decided I would give these Buddy Clubs a try. Upon Opening the box, everything looked great! Good Quality parts. I got to install them and immediately had crazy rubbing issues. It was pretty low in the rear, so I raised it up and still had bad rubbing issues. The Spring rate that comes on the rear is extremely SOFT. The dampening adjustment is also laughable. Whether it was on the softest or stiffest setting, it felt exactly the same. The rubber bushings on the rear bottom cup cannot be used, instead there is metal to metal contact of the bottom perch and cup. I purchased a set of Linear higher spring rate springs for the rear to see if this solves my issue. Hopefully it does, because if I can barely drive it regularly how am I going to be able to track it. I did contact Buddy Club about the issues, but they didn't really offer any assistance, besides "higher spring rate". No shit? I already knew that! They requested pictures, which I sent, and have not heard back from them.
I DO NOT RECOMMEND THESE COILOVERS TO ANYONE. Ride like garbage. 1 out of 5 stars.
P.S. The Old Prototype versions of the Megan Racing coilovers I got for free back in the day were WAAAY better than these.
Old Feb 21, 2013 | 01:41 PM
krunk13's Avatar
why is everyone else running these then? are only the gd versions crappy?
Old Feb 21, 2013 | 01:55 PM
I run THIS
I don't know about the GE. Most people on this forum only care about slamming the car... it rides shitty when you are that low, so they can't tell the difference. I actually track my car. so I need the suspension to work properly. In any case, the product is horrible. I'm probably gonna buy some KW's and just burn these.
Old Feb 21, 2013 | 03:21 PM
I've heard the KW are a bit soft for tracking.
Have you considered calling up AMR?
Old Feb 21, 2013 | 03:41 PM
I run THIS
I've talked to Andy before regarding a setup. I have driven on the Variant 2's before and were nice.
Old Feb 21, 2013 | 04:11 PM
Cool, GL with it.
Old Feb 25, 2013 | 11:17 AM
I run THIS
Buddy Club still not responding to my emails. DO NOT BUY!
Old Feb 25, 2013 | 01:38 PM
Wafulz's Avatar
i have no issues mines rides like a bosssss in track or touge
Old Feb 25, 2013 | 02:37 PM
I run THIS
I highly doubt that. The spring rates on these are WAY too soft for the track. My car has a ridiculous amount of body roll. What pisses me off the most is they told me to get stiffer springs, yet don't offer any. I sent a few emails to them and didnt get a response. Over the past 10 years I have had a good amount of various coilover setups on different cars. 3 on the Fit.... and like I said, these are the WORST i have ever had on any of my cars. Customer service is EXTREMELY Lacking as well. O yea also forgot to mention, if you are running adjustable sway bar endlinks, they will not work with these coilovers.
Old Feb 25, 2013 | 02:51 PM
Wafulz's Avatar
Spring rate yes its a tad soft but for me its fine as i see ur a hard core tracker im a occasional tracker i feel ya would be nice if it was a 13k 11k
Old Feb 25, 2013 | 03:06 PM
I run THIS
I have a 3 finger gap in the rear, and on acceleration it compresses enough to rub. That's WAY WAY too soft. My car is basically UNDRIVEABLE with these coilovers. Was hoping to get the springs I ordered by this past weekend, but they haven't arrived yet.
Old Feb 25, 2013 | 03:47 PM
Mini_Odyssey's Avatar
So since they are soft, does that mean they are very comfy street coilovers?
Old Feb 25, 2013 | 03:52 PM
TPColgett's Avatar
That is AWFUL...
Out of curiosity, would you mind sharing some of your spring rate'damping history with me, via PM if you prefer?
I'm trying to tweak for my AutoX setup and would LOVE your input...
Old Feb 25, 2013 | 04:10 PM
Wafulz's Avatar
Woah ur a three finger gap and rub damm thats no no : / better spring rate for SURE!
im a 10mm gap all around only rub front lightly at 85mph+ turns
Old Feb 25, 2013 | 04:12 PM
I run THIS
Not really. The ride is actually not all that comfortable. Every time I took the car out is just made me more upset how bad the coilovers are.
Old Feb 25, 2013 | 04:13 PM
TPColgett's Avatar
Keep in mind JDMchris has a GD which is not going to be the same as your GE setup. GE's came with significantly softer spring rates OEM let alone whatever your coils have.
Old Feb 25, 2013 | 04:23 PM
Wafulz's Avatar
dam that sucks : /
as for soft ride mines pretty comfy wife does not mind ride at all and she 6 1/2 months pregnant
Old Mar 1, 2013 | 12:06 PM
Wafulz's Avatar
So.. Chris what tire size and rim set up r u running becuase U left that detail out
Also what set up were you running before buddyclub
I have no issuse at all on my 205
Old Mar 1, 2013 | 12:14 PM
accordguyintake's Avatar
Lol I don't see the issue with these coilovers at all. The only real change I've done is upgrade the rear spring from a 6k progressive rate to a 6k linear rate. I've driven in a GD3 with KWs and I would say it's not much of an improvement. I've driven a GD3 with Skunk2 coils and these are days and days better in terms of comfort.
I feel a ton of change when making just one click of adjustment... I don't know what your shocks are set at Chris but I have it under 5/15 on all corners and when I take my car to the track, I have it a little stiffer but still under 7/15 or halfway of full stiffness and it feels plenty stiff to me. Maybe you just aren't that sensitive to the changes? One click can honestly shift my car from a general understeer to neutral/oversteer.
They can sell you a 6k linear rate rear spring if you please, which I would recommend from what you are saying Chris or since you already bought stiffer ones, wait and install it and see if there is any change. Or, why don't you just try using your old rear springs off your old coilovers for now and see if there is any change?
I've had my N+s for literally 45,000 miles and thoroughly enjoy them. I've taken my car to so many track events I can't even count on them and I never once felt that they were holding me back in any way. Even after making 170whp they still feel like they're up to the task to handle my abuse. Hell, I even take my car off roading once in a blue moon AND I took it to a RallyX event with the coils. They dampened well and survived it.
At the end of the day, these are street oriented coils that could handle track if needed, and I think it is made just as they described. Definitely no big luxury sedan ride but I could say it's similar to a sporty sedan like a BMW M3 or something. It can't handle big bumps but it definitely rides in "normal" conditions very well. Anyways if you enjoy ricer videos of coilover abuse <3
Old Mar 1, 2013 | 12:42 PM
Wait, wait, wait.
Dawg, the Fit rides worse than an M3 stock.
