L13 to L15 swap
Old Mar 17, 2013 | 07:50 AM
onetwothree's Avatar
L13 to L15 swap
Has anyone done a L13 to L15 swap?? If so I have some questions
Old Mar 18, 2013 | 12:24 PM
ThEvil0nE's Avatar
and your reason for the swap?
Old Mar 18, 2013 | 02:06 PM
TPColgett's Avatar
Hmm.. Not seen anyone on here do one. Guessing at least ECU and Harness will be a challenge...
OP are you doing this to look for more power?
Old Apr 2, 2013 | 08:05 AM
Just want a little upgrade from my 1.3 to 1.5, it's all good if noone has done it probs won't even do it anyways, it'll b a waste
Old Apr 2, 2013 | 09:18 AM
krunk13's Avatar
I think they may be the same engine. The bore is the same but the strokes are different so you might be able to get away with changing internals/ecu instead of the whole engine.
Old Apr 2, 2013 | 01:09 PM
TPColgett's Avatar
The 1.3 has the i-DSI head. It's a 8 valve twin spark plug per cylinder head designed for cleaner emissions and maximum fuel economy with an emphasis on power in the low to mid end. Torque peaks at like 2700rpm
There is a 1.5 i-DSI out there somewhere, but I think the OP is looking to switch to the 1.5 L15A VTEC engine like we all received in the North American market. At the VERY least, it would be a head swap (this would include intake/exhaust manifolds), ECU and harness....
Parts are most likely out there, and they are beginning to get cheap here in the US...
Pics/info came from this excellent article: The Truly Amazing Honda Fit/Jazz
Old Apr 2, 2013 | 01:16 PM
DiamondStarMonsters's Avatar
Tyler is correct, this is not a simple or cheap undertaking. You would be better off turbocharging the 1.3 for the time/cost.
Old Apr 4, 2013 | 03:46 AM
Cheers for the answers mate
Old Jan 15, 2014 | 08:15 AM
Smoodshaft's Avatar
I did the swap from L13a to L15a vtec,also change to l15a wire loom and ECU. Now Car hunts from aroud 1500rpm to 2800rpm.tranny sport mode also not working.
Old Jan 15, 2014 | 09:49 PM
What did you have to change? Whole engine?
Old Jan 15, 2014 | 09:52 PM
Smoodshaft's Avatar
Yes I did change the whole engine.
Old Jan 15, 2014 | 10:00 PM
Smoodshaft's Avatar
Finally get the sport mode to work. Using the L15a wire loom with L13a ECU ,am also planning on using aem f/ic 6 to tune the engine.
Old Feb 3, 2014 | 12:48 PM
King cRv's Avatar
What did you do with the wirings? Specially to the dashboard wiring goin to the engine? Thanks!
trinisir
22
Aug 29, 2009 08:23 PM
Bukwheat
Sep 25, 2008 07:02 PM
1990hondahf
40
Apr 3, 2008 11:51 PM
ascGD3
Nov 12, 2007 02:56 PM
azkikersfit
16
Apr 27, 2007 12:54 AM
