High Speed Vibration
Old Mar 20, 2013 | 10:52 PM
phenoyz's Avatar
at 80mph i didnt notice any vibration, but at 100mph i notice a slight vibration which i thought was the wheels.
The steering wheel is fine....
i just had the wheels balanced and rotated.
my car has 40,000 miles already, is an alignment needed?
(car DOES NOT veer to the right or to the left)
what could cause that vibration at 100mph?
what can be done to correct it?
my suspension is stock, i have a 15x7 aftermarket wheels
the vibration IS NOT STRONG, i would say a "SLIGHT vibration"
there is NO sound or anything underneath
is that NORMAL when you hit 100mph?
Old Mar 20, 2013 | 11:59 PM
MTLian's Avatar
I have the same issue in my 2007 GD Fit at about 80 mph. The previous owner had painted the calipers and drums bright red, but he didn't tape the mating section of the wheel. I was told this might cause a slight unbalance, and be the source of the vibrations at highway speeds.
Old Mar 21, 2013 | 12:54 AM
macbuddy's Avatar
"Hub Centric Rings?"
Do your aftermarket wheels require "Hub Centric Rings?"
Old Mar 21, 2013 | 01:01 AM
phenoyz's Avatar
i dont think i needs it...?
my wheels are Enkei RPF-1, 15x7, (tires are kumho ecsta 195/55)
maybe i need to have the wheels and tires Re-Balance?
Old Mar 21, 2013 | 02:12 AM
ThEvil0nE's Avatar
yes, balance check them and prolly rotate them too.
I've gone in the 100mph and over on the fit, have not had issue with vibration and I don't have hub centric rings either.
Old Mar 21, 2013 | 03:31 AM
martamaus's Avatar
maybe check for bends.. even small ones can cause vibration
Old Mar 21, 2013 | 03:34 AM
macbuddy's Avatar
...So you are "lug centric"...
Are you using the correct type of lug nuts on your RPF-1s? After listening to the tire/wheel guys that I deal with, I learned that some lug nuts for my RPF-1s seat better than others. The tuner lugs that I originally wanted, weren't a good fit. So, I had to look for a different set.
If you decide to go without hub centric rings, at least make sure your choice of lug nuts are a good match. Also, if you go "lug centric" they say to tighten the lugs with the wheels off the ground.
Here is a discussion about using "hub centric rings." Maybe this might help you solve your vibrating wheel problem.
Hubcentric rings. Are they truly necessary?: Grassroots Motorsports forum: Grassroots Motorsports Magazine
Old Mar 21, 2013 | 03:45 AM
loudbang's Avatar
Most balancers don't spin the wheels fast enough to catch variations in balance at 80 mph. Maybe try another place and let them know the problem you are having.
Or find a place that balances the wheel, hub, and rotor as one unit while on the car. The only drawback is that you will need to keep that wheel in that position every time you take off a wheel.
Old Mar 27, 2013 | 04:00 PM
x_25's Avatar
Likely a slightly off balance wheel at that speed. Most local shops that I have been too seem to end up with one tire (at least) slightly off balance, that will only show at higher speeds. (Right now I have a vibration that shows up around 70mph, but I am running studded snows, so shouldn't be going too much faster anyway.)
Old Mar 27, 2013 | 08:27 PM
fujisawa's Avatar
Originally Posted by phenoyz
at 80mph i didnt notice any vibration, but at 100mph ..
WELL THERE"S YER PROBLEM!!! :P
That's 15mph over the highest speed limit anywhere in America and 35 over the typical 65. You're asking the wrong question. The right question is, "Am I simultaneously foolhardy and selfish to drive so fast on public roads," and the answer is yes.
If you're looking for a semi-technical reason to stop doing it, I'll gently point out that a BMW (any of them) is designed to be controllable and reasonably safe at 125mph, assuming the road is well-maintained. The Japanese rarely drive over 100kph, and I've rarely encountered highways in America a German would consider well-maintained. So stop doing it in the Fit.
Old Mar 27, 2013 | 10:47 PM
phenoyz's Avatar
i am using the oem lugnuts...
probably gonna have my wheels rebalanced
at 100mph the fit is very stable/controllable, wanted to go more than that had that slight vibration not happened
Old Mar 31, 2013 | 02:58 AM
macbuddy's Avatar
You might need different lugs...
I am not sure what type of lugnuts your OEM lugs are, but here in US, our's are of the "ball seat" type. The RPF1s that I have require a "cone seat" type lugnut to achieve the most seat area. Also, there is a chance that your OEM lugnuts are not fully seating. Anyway, take a look at this link:
Can I use original lug nuts for custom whees?
Old Mar 31, 2013 | 05:07 AM
phenoyz's Avatar
the ones i am using are the ones that came from the factory for my
rpf-1, 15x7...do i need to buy aftermarket lugnuts for the rpf?
if this is a safety issue, what are the good aftermarket ones that will
fit the rpf's best?
thanks
Old Mar 31, 2013 | 08:02 AM
Gra-fit-e's Avatar
No on has said a bad tire yet.
- although 2 of you have the problem.
-- but, if ONLY 2 of you have the problem... ...although not everyone is going to go 100mph to find out...
GL
Old Mar 31, 2013 | 08:17 AM
boatfloyd's Avatar
100 mph
I don't have to go 100 mph in "My Fit". I will take your word, that it will go 100 mph. Thanks for the information. Foyd Boat.
robotfist
Jun 1, 2012 10:52 PM
mkht78
Sep 16, 2009 07:25 PM
jani88
May 6, 2008 11:09 PM
Navin323i
Dec 1, 2007 01:23 PM
phil_qc
May 14, 2006 09:02 PM
