how to tell gen 1 or gen 2
Old Apr 10, 2013 | 09:16 PM
Kasek's Avatar
hey ive been reading all sections of the forums for a while and i have an 08 fit. Im wondering where i read on the forums the gen 1 or gen 2 how can i tell thanks
Old Apr 10, 2013 | 09:44 PM
Hootie's Avatar
By reading the Vehicle Identification Number.
If it starts off JHMGD, then you have a 1st generation GD-chassis Fit.
If it starts off JHMGE, then you have a 2nd generation GE-chassis Fit.
In your case, you'd mostly likely have a 1st gen GD like I do.
Old Apr 10, 2013 | 09:51 PM
Kasek's Avatar
oh wow thats easy.... thanks for the help and rep to you
i do have a gd
Old Apr 10, 2013 | 10:26 PM
Yeah in the USA/Canada, the second generation started in the MY2009
Old Apr 10, 2013 | 10:36 PM
Kasek's Avatar
thanks for the info do you no if its possible to get the sport model key with attached fob for the base model fit to work. i ask dealers and they say no but i thought id ask here as well thanks dont wanna start a new thread
Old Apr 10, 2013 | 10:42 PM
Hootie's Avatar
What trim level is your Fit?
If its a Base model (LX in Canada I believe) it will need the keyless entry add on/accessory programmed.
VIN should start off like JHMGD384 if you have an auto or JHMGD374 you have a manual if memory serves me right.
Old Apr 10, 2013 | 10:49 PM
Kasek's Avatar
i have the base model fit so im asssuming LX and i do have the keyless entry as i have a remote with lock unlock and panic, then my key is just a normal key that has immobalizer i think.....
edit: i forgot i have automoatic vin starts with JHMGD384
Old Apr 10, 2013 | 10:56 PM
Hootie's Avatar
Ah I see. More than likely, it should work provided that the keyless entry system in your Fit is a Honda OEM/Accessory one. You'll need to either have a Sport key cut and programmed at the dealer (so it can communicate with the immobilizer system) or have one cut and transfer the immobilizer chip from your keyless entry fob and insert it into the Sport key (not responsible for damages or it not working though).
Old Apr 10, 2013 | 11:01 PM
Kasek's Avatar
ya its OEM.... Ill have to make a post i guess asking if anyone has don it before i go to the dealer asking to do it when they say it isnt possible. Then waste my money lol. Anyways thanks for the help ill make a post and hopefully get mroe info
Old Apr 10, 2013 | 11:14 PM
Hootie's Avatar
Just use the search function to see if anyone has done that. If you haven't found any answers, then post up the question.
radioarno
Feb 5, 2018 11:53 AM
radioarno
Feb 5, 2018 07:18 AM
StromsonFit
Jan 14, 2012 10:17 AM
running
Feb 12, 2011 01:22 PM
sxpirate
Feb 25, 2009 11:31 AM
