Help Needed - Wheel Fitment Question!
Old Apr 18, 2013 | 12:27 PM
CHRISP1's Avatar
Hi guys,
So I may be switching up the wheels on my 2012 Sport and had a question in regards to fitment for a 15" wheel setup. I'm pretty sure I would be safe for proper fitment in the rear but I'm not to sure about the front..
The setup's I'm thinking are:
1.) 15x7 +35 Offset (All Around)
2.) 15x7 +38 Offset (All Around)
Tire size may be 205/50/15
So do you guys think these setup's will fit both front and rear without sticking out past the fenders?..or at least be flush/tucked in a bit?
As long as they dont stick out I would be happy!
Any insight on this would be appreciated..even pics if any!
Thanks in advance!
Old Apr 18, 2013 | 01:13 PM
TPColgett's Avatar
Here is a useful calculator Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
There are several user's on here running 15's, FitDEEZ is one example https://www.fitfreak.net/forums/2nd-...ssm-ge8-2.html
"15x7.5 +32 .. 5mm spacer in the rear 205/50/15 in the front and 205/55/15 in the back .."
pig_pit as well ran 15's https://www.fitfreak.net/forums/2nd-...new-car-3.html
"15X8 tires are 195/50 F"
15's on a GE seem to work as long as the car is VERY low, at least aesthetically speaking...
Either of your options should work, depending on how low you are, and the difference between +35 and +38 is not HUGE. If your going to run the meatier 205 and are low, I'd go +38 to be safe
Old Apr 18, 2013 | 01:21 PM
CHRISP1's Avatar
Thanks for your help man! I'm using the eibach pro-kit so its pretty low but not slammed. I'm looking at these 15" wheel options because all the styles I seem to find that I really like are in 15" lol. As you know the Sports run 16's.
Based on Fitdeez above specs and pics..he's running .5 more width and offset is lower so realistically these options should fit and not stick out..
kj9024kr
Jan 29, 2016 05:45 PM
kurisux92
Dec 15, 2011 10:08 PM
Blueputtputt
Apr 29, 2010 12:55 AM
inxsole
Nov 4, 2009 12:55 PM
HB1320
Feb 14, 2009 01:09 PM
