2007 Fit getting louder when I look under and see..
Old May 16, 2013 | 11:27 PM
FitFieFoeFum's Avatar
Unhappy 2007 Fit getting louder when I look under and see..
https://i.imgur.com/UPU6t3G.jpg
What is this piece called and will it be expensive to get fixed? I is sad
Old May 16, 2013 | 11:43 PM
jmsplitfyre's Avatar
That is just the heat shield for your catalytic converter. You probably ran over something and ripped it off. It's not really that important, some people just remove it all the way.
Cheer up!
Old May 17, 2013 | 09:18 AM
BurntZ's Avatar
Cat Converter Heat Shield
taking the heat shield off is fine ONLY if you park on clear/clean cement/black top 100% of the time. If you ever park over grass or where there is a small pile of leaves, the super heated cat, now exposed, can easily set grass/brush/leaves on fire. So if you don't mind seeing your car go up in flames, I'd avoid ripping the heat shield off. It does serve a purpose.
Old May 17, 2013 | 12:35 PM
Yikes with a name like Burntz, I tend to believe you when it comes to fire!
Is a heat-shield a 'generic' part that I can get replaced (and how much$$) or is it something I'd need from a Honda dealer and pay out the wazoo..
Thanks
Old May 17, 2013 | 02:04 PM
Wafulz's Avatar
metal wire and tie it lol tight so no rattle if u wanna YOLO it cost 6 bucks walmart
Old May 17, 2013 | 02:33 PM
Black3sr's Avatar
Cheap Canuck wants to fix it himself. As the converter should be still wty by Honda maybe the shield is too? Give them a call. It would save having to spend a couple Toonies on wire.
Your pic and where in Canada?
Old May 17, 2013 | 02:45 PM
BurntZ's Avatar
Agreed. The Cat is warranted for much longer than the bumper to bumper warranty and may be covered by the dealer. As for cost, I would knit myself a new cover before ever paying money to a dealer. I have a long time relationship with a mechanic and would always take it there first. I suggest you find a reputable one in your area. For instance, after buying this car a couple of weeks ago and reading all your great advice, I asked both Honda and my mechanic for quotes on adjusting the valve clearances. My mechanic was over $150 cheaper.
Old May 17, 2013 | 03:13 PM
blaaaackfit's Avatar
Out of pure curiousity I called the dealer to find out how much a replacement cat costs, (I was about to sell mine).... lets just say if you could get your hands on someone's used one do it. It is a really expensive part.
Old May 17, 2013 | 04:03 PM
as others have already mentioned, if you dont park on lawns and stuff, you really dont need it.
Old May 17, 2013 | 04:07 PM
DrewE's Avatar
A replacement catalytic converter? big bucks for sure, but covered by the emissions warranty for quite some time (at least in the USA, as required by federal law).
The sheet metal heat shield? That is a whole lot cheaper to replace. But from the looks of things, it doesn't need to be anything more (for the OP) than bending the existing shield back into position and reattaching it somehow, with some new bolts or wire or whatever.
Old May 18, 2013 | 01:24 AM
loudbang's Avatar
The heat shield is made of thin sheet metal so you could take it off and straighten it out very easily possibly using just your fingers then put it back on.
Old May 18, 2013 | 01:44 AM
n9cv's Avatar
I have never had to mess with one on a Fit but on most vehicles it is a simple bolt or clamp on arrangement. A wire or a heater hose clamp (less than $1.00) would probably hold it in place again.
Jared592
Jul 10, 2017 10:44 AM
RA020726
Sep 29, 2015 04:00 AM
radiolandog
Sep 3, 2013 09:04 PM
hondafn
Mar 21, 2013 05:36 PM
im the fit
May 30, 2009 01:28 PM
