WHAT is falling off the undercarriage of my baby!?!?!?
Old Mar 19, 2013 | 08:22 PM
hondafn's Avatar
Hello.
First, there was noise.....then a scrape....then....oh man.....
i noticed something hanging from my underside. I cant afford to bring it in right now so im asking my fellow fitties to help me with identification of the problem.
thanks ya'll!!!
Old Mar 19, 2013 | 08:30 PM
Wanderer.'s Avatar
rusted out catalytic converter heat shield?
Old Mar 19, 2013 | 08:31 PM
TPColgett's Avatar
That looks like a cat!!!
Front half of car on the passenger side? Did the exhaust get REALLY loud?
Are you running boost?!? It looks like it detonated!!! o_O
I hope its just the heat shield...
Old Mar 19, 2013 | 08:42 PM
hondafn's Avatar
I had a feeling it was the Cat converter shield.
It is in the front right in the middle (but behind) the front tires.
Old Mar 19, 2013 | 09:03 PM
dewthedew's Avatar
looks like the heatsheild rusted or got smashed off
Old Mar 19, 2013 | 09:14 PM
fujisawa's Avatar
The heat shield is "optional" in the sense it doesn't help the car much. It supposedly helps the cat heat quicker in cold weather. BUT it has the pretty IMPORTANT function of reducing undercar brush fires in dry, hot climates (if you are dumb enough to park a hot car 4 inches over dry grass, you see).
One thing I'll say is, don't leave it hanging there. Remove or replace, because as it is now, eventually it'll snag on something .. trust me ..
Old Mar 19, 2013 | 11:02 PM
doctordoom's Avatar
Supervillain
Is your car lowered? Where did that gaping hole in the shield come from?
Old Mar 20, 2013 | 12:43 AM
loudbang's Avatar
Heat shield for the converter. Pull it off and run it. Fix it when you have time.
Old Mar 21, 2013 | 12:08 PM
Doug Just Doug's Avatar
Do I see some other minor damage under there -- looks like some missing paint. Maybe you ran over something or bounced over a curb or something at some point?
Old Mar 21, 2013 | 05:36 PM
Carbuff2's Avatar
PLEASE get that damaged shield off the car before it cuts the Oxygen Sensor wires!
alojzije
Aug 17, 2017 06:35 AM
RA020726
Sep 29, 2015 04:00 AM
radiolandog
Sep 3, 2013 09:04 PM
FitFieFoeFum
May 18, 2013 01:44 AM
im the fit
May 30, 2009 01:28 PM
