Rear license plate
Old Aug 17, 2006 | 03:02 AM
hqly's Avatar
Rear license plate
i think only the top of my lic plate is screwed in so when i close the back hatch the plate rattles.. how can i eliminate this rattling? kinda annoying
Old Aug 17, 2006 | 03:13 AM
whitefitsport's Avatar
same thing here! it went away on its own though...
I wanted to try tightening the screws or adding screws on the bottom (?)
Old Aug 17, 2006 | 07:03 AM
vividjazz's Avatar
Someone that Posts too much
Old Aug 17, 2006 | 07:24 AM
Blue Dogg's Avatar
I'm thinkin a couple half inch squares of the foam double sided sticky tape stuff should do it. Placed in the areas of the plate that makes contact. Look in your junk drawer, you probably already have some.
-OR-
Some of those peal and stick rubber bumpers that you can put on your kitchen cabinet doors to keep them from making noise. Many styles, sizes, and types available at your local hardware.
Old Aug 17, 2006 | 07:10 PM
Joe_Schmoe's Avatar
My Fit came with two stips of foam behind the plate. They're about 1" wide, 4" long, and 3-4" apart. No rattling here.
Old Aug 17, 2006 | 09:09 PM
joe FIT's Avatar
I too, used foam tape, to keep the rear plate from rattling. I also bent it at the top a small amount to keep it firmly pushing against the foam at the bottom, then tightened it.
Old Aug 21, 2006 | 08:19 PM
FitInFla's Avatar
My ratttling was from the license plate frame. Since it was a dealer advertisement I removed it. Rattling gone.
Old Aug 21, 2006 | 08:40 PM
Packy's Avatar
Frequent FitFreak Poster
Yup, same with mine. The bottom of each strip of foam is right where the bottom holes on the license plate are.
Old Aug 22, 2006 | 12:39 AM
catsupsam's Avatar
I used the velcro squares that come with adhesive.
It works great! Put them on the foam pads and on the back of the plate.
They are rock steady, and removable.
Old Aug 22, 2006 | 01:15 PM
revs to 9's Avatar
Honda Fit Forums Moderator
mine has the foam as well. but my rattling came from the dealer frames as well. removed and no problems.
Old Nov 24, 2008 | 11:30 AM
JDMxGE8's Avatar
I'm experiencing a lot of rattling from the rear license plate too. It's hella annoying.
Old Nov 24, 2008 | 04:32 PM
fittmann's Avatar
License Plate Rattle
Try applying some foam tape to the points of contact. Our good friend 3M should be able to supply what you need. Apply it on the back behind the screw holes and anywhere else it might make contact with the hatch. Should end that annoyance! BTW: It worked for me!!
'07 VBP Sport 5MT w/minor appearance & comfort mods!!
veazer
May 11, 2015 03:24 PM
ZXRider
Aug 19, 2010 05:30 PM
polokid69
Oct 16, 2009 06:49 PM
davis61381
Sep 20, 2008 10:01 PM
LDO
Oct 17, 2007 12:27 PM
