Need to know header!
Old Jul 22, 2013 | 11:31 PM
Maty J's Avatar
Hi,
the weapon r ss race headers are looking damn good and want to grab myself a pair. Im running the 1.3 idsi engine, Ive read a few things, some fellas saying the l13a and l15a have the exact same header bolt pattern. Im just trying to get a 100% guarantee that they'll fit (minus the dreaded fitting issues I've heard they have already :P) does anyone have any pictures they can post of the 1.5 header setup? So I can literally compare the pic to my engine!
cheers
Maty
Old Jul 23, 2013 | 12:10 AM
macbuddy's Avatar
Here's a thought. Check with the Honda parts database. See if the exhaust manifold gasket part number is the same on both engines. If so, at least you will know that it will bolt up. Whether it fits in the engine bay might be another issue.
Old Jul 23, 2013 | 01:35 AM
Maty J's Avatar
thanks for that blatantly obvious reply, so I did just that :P and yep they match, in fact, there's quite a few city/civic/fit(jazz's) that are all exactly the same! Handy to know, from what ive seen with the engine fitment and subframe all the GD models are identical, so looks like im going to be running a weapon r race header on a 1.3 hah, well it'll be a one of a kind, should sound interesting!
Old Jul 23, 2013 | 01:43 AM
jmsplitfyre's Avatar
There's a video on YouTube of the install of this race header, but it was the 1-pc prototype. The final product is the 2-pc 4-2-1 header now. I am saving up for this header too! Let us know how it goes!
Old Jul 23, 2013 | 03:17 AM
loudbang's Avatar
Just like I told you they were the exact same several weeks ago
Guess you are sure now.
Old Jul 30, 2013 | 09:11 AM
Maty J's Avatar
hah loudbang indeed you did, I get so sure on one idea then some douche comes along and says "no of course its not the same" and bang, doubting again, but now i do know 100%! thanks for your advice man! Another quick q, how important is the resonator? My entire system will be weapon r race headers/down pipe, to a 2" b pipe with a high flow 200cel cat, possibly a resonator here after (glass pack?), to my current 2" axle back magnaflow straight through muffler, do I need this resonator?
Old Jul 30, 2013 | 09:32 AM
De36's Avatar
Here's the cheapest and most accurate solution:
Buy a 1.5 exhaust manifold gasket. Then remove you header and match up the 1.5 gasket to your head.
I have the weapon-r header, it wakes the car up and makes it loud.
1. Buy the weapon-r CEL delete.
2. The header does not come with gaskets, buy the OEM header gasket and egr gasket.
3. You will also need additional hardware for the egr pipe: (x2) 8x25mm stainless bolts and brass nuts
4. And hardware for the header to mid pipe: (x3) 10x35mm stainless bolts and brass nuts
Old Jul 30, 2013 | 11:17 AM
IIRC, the Weapon-R race header eliminates the cat already.
Old Jul 31, 2013 | 01:28 AM
loudbang's Avatar
The resonator just helps reduce the sound. If you don't mind the noise and can pass inspection it is not necessary.
jevin
Feb 18, 2012 05:54 PM
kevinkidstar138
Feb 23, 2010 07:24 PM
Padraic
Dec 8, 2008 04:51 PM
vbo
17
Jan 27, 2007 02:49 AM
alanranch
Jun 22, 2006 09:06 AM
