How do I open the hatchback when the battery is dead?
Old Oct 11, 2013 | 05:44 PM
Jensen Healy's Avatar
Forget it, I found a way to manually override the power switch on the hatchback doorlock.
Old Oct 14, 2013 | 09:53 AM
PaleMelanesian's Avatar
Do you care to share that information with us? It might be useful to someone someday.
Old Oct 14, 2013 | 10:20 AM
Wanderer.'s Avatar
I never even realized this could be a problem. Would love to hear the workaround.
Old Oct 14, 2013 | 11:02 AM
cyanosis's Avatar
I know in the ge8 there's a procedure in the owner's manual. some kind of switch on the tailgate that's usually covered by a plastic panel.
Old Oct 14, 2013 | 12:00 PM
spreadhead's Avatar
On an 07-08, on the inside of the rear hatch, there is a rubber plug. Remove this plug. Inside there is a lever. Push this lever to the side. This will unlock the hatch. Open the hatch as normal from the outside. This is explained better in the little book that comes with Fits. Don't know about 09s forward.
Old Oct 14, 2013 | 06:44 PM
Steve244's Avatar
Old Oct 15, 2013 | 02:16 AM
n9cv's Avatar
I think you guys overlooked the obvious. Throw a set of jumper cables from another vehicle on the Fit battery. You will now have power to unlock the hatch. You could also use a jumper pack.
Old Oct 15, 2013 | 11:57 AM
Originally Posted by Steve244
Old Oct 15, 2013 | 11:58 AM
Seems to me the obvious and simple thing is a manual switch you can flip to unlock it. Like the one Steve posted.
Old Oct 15, 2013 | 12:07 PM
then why did you post asking for this info earlier?
Old Oct 15, 2013 | 12:08 PM
I didn't know then. Now, thanks to Steve's post, I do. And it's simple. I expected there would be a straightforward manual method.
The "obvious" was aimed at the jumper cable suggestion.
cyanosis's Avatar
if it's a power issue sure. what if it's an electronics issue?
Old Oct 16, 2013 | 03:56 AM
n9cv's Avatar
I believe his original posting said it was a dead battery issue.
SilverEX15
Jan 12, 2015 03:22 PM
SilverEX15
Jan 10, 2015 05:51 PM
vickenp
Aug 1, 2013 11:47 PM
mrestino
Jul 16, 2013 08:44 PM
NHB_Fit_07
Nov 7, 2011 07:43 PM
