Strange marking inside oil filter.
Old Dec 6, 2013 | 08:32 AM
Hondicious's Avatar
I was looking at some Honda oil filters and I noticed that they have what appears to be red marker pen marks in the center. Is this normal for Honda oil filters!?
I don't know why the filters don't come with tear off plastic film covers like other manufacturers! Are you listening HONDA!?
Old Dec 6, 2013 | 01:35 PM
Wanderer.'s Avatar
Probably just QA marking.
All my Honda filters i've ever gotten were shrink wrapped...
Old Dec 6, 2013 | 01:40 PM
Rampo's Avatar
Same here. Here are the last two I just received from College Hills Honda:
Old Dec 6, 2013 | 03:33 PM
Rampo's Avatar
Just an observation, the filter referenced by the OP has 6 holes on the open end, whereas the ones I'm showing, have 8 holes. (not counting the threaded center hole)
Old Dec 6, 2013 | 04:08 PM
painterguy's Avatar
Senior Member
I can not see the reference pics being at work. With that being said I have never seen any Honda o/f come from Honda without it being in a plastic wrap. Not sure about other countries of Origin but the USDM stuff is plastic wrapped.
Old Dec 6, 2013 | 04:16 PM
Wanderer.'s Avatar
Good catch Rampo, also that rubber is usually orange, not white like in OP's pic, and the canister is blue, which should be visible in that pic.
The S2000 filters have 6 holes.
I don't think that's a Honda filter though in the original post. Best explanation for all the discrepancies I see.
Old Dec 7, 2013 | 06:47 AM
Hondicious's Avatar
Thanks guys. Filter is genuine Honda filter for UK Jazz (1.4 litre) which is similar to Fit. Filter is made by Purflux in France. It's packaged in a cardboard carton but not sealed
Anyway my oil has been changed. Old oil filter had the same red markings so like you say must be some kinda factory marking. Just panicked when I saw it.
I note that oil sump drain bolt had no magnetic insert. Guess I won't regret changing the oil every 6 months then.
Old Dec 7, 2013 | 12:05 PM
Marrk's Avatar
As far as I know, USDM cars have no magnetic insert either. If that helps any.
Old Dec 7, 2013 | 05:40 PM
mahout's Avatar
Those red marks look like assembly marks meant to identify an action done correctly.
Scott
Mar 27, 2015 06:02 PM
hqly
Jul 11, 2014 10:00 PM
Evan_2k
SoCal Classifieds
Oct 18, 2010 01:54 AM
Lek
Jul 4, 2009 03:34 AM
stew32
Jan 6, 2008 11:40 PM
