camber question
Old Dec 30, 2013 | 11:31 PM
Nvillegas's Avatar
camber question
hey guys just a quick question about front camber i have a gd3 and i just out on enkie 92 15x8 +25 offset. front are sticking out,and i know i need some camber bolts..but is there any other way to adjust front amber?..like to make it negative? I'm going to hav alignment tomorrow..so i just wanna know before they align everything...thanks
Old Dec 30, 2013 | 11:55 PM
palos's Avatar
Camber plates, if available.
Lowering springs will reduce camber, but possibly create clearance issues with the fender.
Old Dec 31, 2013 | 12:29 AM
Nvillegas's Avatar
thanks for your response..im on coil overs and I'm thinking if the 2 bolts from the lower strut can be adjusted to positive and negative camber?
Old Dec 31, 2013 | 12:35 AM
2poler's Avatar
you need to get two sets of camber bolts
Old Dec 31, 2013 | 12:37 AM
Nvillegas's Avatar
ok maybe ill get them before alignment...how much negative degrees i could get with camber bolts?
Old Dec 31, 2013 | 12:39 AM
Nvillegas's Avatar
do local auto parts store have camber bolts?..or just have to order it online?
Old Dec 31, 2013 | 12:43 AM
2poler's Avatar
You should get around 3 degrees. There is a thread somewhere around here with a Toyota part number for the bolts. Something like $25.
Old Dec 31, 2013 | 12:44 AM
Nvillegas's Avatar
ok thai you sir..
Old Dec 31, 2013 | 10:48 AM
palos's Avatar
Only one set of camber bolts is intended to be used on the front. Ask whether the shop will install/adjust two sets.
Old Jan 1, 2014 | 12:37 PM
Previc93's Avatar
http://www.hrsprings.com/products/triple-c/
I have 2 sets of these for my race car. I'm at 2.6 degrees but the most is 3 degrees that I could get.
Old Jan 2, 2014 | 12:46 AM
Nvillegas's Avatar
Originally Posted by Previc93
H&R ‘Triple C’ Camber Adjustment Bolts | Products || H&R Special Springs, LP
do you have pics?..i already order a set..and hopefully put them on tomorrow, my rear was rubbing so bad that i have to raise the back up a lil bit
Old Jan 2, 2014 | 12:12 PM
Previc93's Avatar
Pics of the car or the bolts
Old Jan 9, 2014 | 12:19 AM
Nvillegas's Avatar
pics of the camber
Nvillegas's Avatar
if i use just one set like the upper bolt..will that give me enough camber?...or not much difference?
Old Jan 9, 2014 | 12:44 AM
painterguy's Avatar
Senior Member
One bolt in the upper hole should get you - 1.75 of camber.
Nvillegas's Avatar
also how easy to install the bolts?...torque specs?
Old Jan 9, 2014 | 12:47 AM
painterguy's Avatar
Senior Member
If you want to get technical the book calls for 66lb ft of torque on the pinch bolts.
If you can jack the car up and take the wheel off you should be able to install the camber bolt.
Old Jan 9, 2014 | 01:05 AM
Nvillegas's Avatar
thank you for the info. ill try it soon i get my bolts...
whitefitsport
Oct 2, 2018 10:54 PM
ciref8
Oct 17, 2014 12:31 AM
SickFit
29
Sep 28, 2012 12:00 PM
nealy
Sep 15, 2009 10:57 PM
FELIXY69
Jul 21, 2009 10:38 AM
