DIY: Which is broken - the key or the lock?
Old Jan 6, 2014 | 05:03 PM
emmarsh's Avatar
I have a 2007 base model Fit w/keyed (not keyless entry) door locks.
The problem started with the driver's side door a few months ago.
The key started to stick in the lock, then worsened to the point
where the key only went in halfway. We could still get into the passenger side door.
Then the same thing happened to the passenger door lock.
The only way to get into the car now is through the back hatch.
Unfortunately, the key is starting to act sticky in the ignition switch now.
The keys we use have a lot of wear on them, so it could be a problem with the keys. The car has spent its life along the northwest coast of Canada where it's rainy year round. Water getting into the locks is a problem since the door locks angle out at the bottom, causing water to pool here.
Should the lock cylinders be replaced?
OR
Should new keys be made?
OR
Both? (I sure hope not!)
I would prefer not to replace this with a keyless entry system,
but if that's the only option, I can live with it.
Cost estimates:
$200/ new key
$250/ 2 new cylinders + the labor to install these.
Thanks,
Ellen
Old Jan 6, 2014 | 08:44 PM
DWils's Avatar
How many keys do you have? Are you using all of them to get into the car? I ask because my 2007 Base has at least two keys. I'm the only person who ever drives it so the extra key has just stayed in a box in my house and could be used as my backup key in the case my first key craps out like yours sounds like it did.
Old Jan 6, 2014 | 09:28 PM
emmarsh's Avatar
We have two keys, but both are worn. Good idea though!
Old Jan 7, 2014 | 07:36 AM
Carbuff2's Avatar
Save that key as a backup.
Also before spending a lot of money, lubricate your locks with the proper liquid:
Graphite lubricants will not gum up the mechanism like regular oils. The liquid carrier evaporates, leaving a dry material inside.
Also, prevent your keys and lock cylinders (especially ignition) from wearing out by reducing any other things that weigh the key ring down. (Other keys, flashlights, store card readers, etc) Use a key fob with a detachable section.
Old Jan 7, 2014 | 08:03 PM
emmarsh's Avatar
Thanks for this. I'll give Lock-Ease a try first.
Old Jan 19, 2014 | 12:55 PM
emmarsh's Avatar
Lock cylinders need replacing - COSTLY!
I tried the Lock-Ease but it did nothing. Then I went to the local locksmith who said it might be that one or more tumblers was stuck. I had the tumblers taken out, but the locksmith could not fix them and I had to order two new cylinders from Honda. Cost:
$ 128 driver's side cylinder
$ 74 passenger side cylinder
$ 150 for 2 hours labor SO FAR to take out the tumblers and door handles
The locksmith said he sees LOTS OF HONDAS WITH LOCKS THAT GO BAD from too much moisture in the tumblers and no regular maintenance with a spray lubricant.
I hope this helps other Honda Fit owners who have the same problem. In the end, this will cost around $5-600. It takes 4-5 days to order the cylinders in Canada. These must be delivered to a Honda dealer. Since we live an hour and a half from the nearest dealer there is an additional shipping charge. It also means we will have three keys to the car - ignition and hatch, driver door, and passenger door. The cost for rekeying all these to match would be around $160 more.
Fortunately this is the only problem we've had with the car, which we bought used in Spring, 2013.
Old Jan 19, 2014 | 03:04 PM
Carbuff2's Avatar
Too bad the Lock-Ease didn't work, but save it for the new lock cylinders (and the ignition, too).
Use it on any car you have, especially before winter when freezing locks are a problem.
Old Jan 19, 2014 | 08:36 PM
DWils's Avatar
Crap! For all the money you're dumping into it you could have bought the keyless entry system! I think the one that I bought was less than $200 from College Hills Honda.
Old Mar 24, 2014 | 05:54 PM
ROTTBOY's Avatar
For the OP's future maintenance of his door key issues, coming from up North the weather is wet and cold. My son (in NJ) had a similar situation last year with his keys not being able to go in the door tumbler and turning. It progressively got worse. With his vehicle out of warranty, my local mechanic suggested spraying 100% denatured alcohol to disperse any accumulated moisture. That did the trick. He also advised against lubing it with WD40 or any other oil based solvent.
Old Aug 21, 2015 | 11:54 PM
dll932's Avatar
I am a locksmith. I live in near Cleveland Ohio where we get plenty of cold weather. I have used WD-40 for about 30 years with no ill effects, however Tri-Flow is better since it has powdered teflon in it. Alcohol will dry out the moisture, but WD or Tri-Flow will displace it, which should be enough. I recommend lubing the locks about 4 times a year-especially just before winter. Now, if you live in a very dusty area, I would use a dry spray teflon lube instead.
doctor J
Mar 8, 2019 05:40 PM
g fit
Dec 19, 2017 05:01 PM
cjmiller14
Jan 1, 2016 12:12 PM
fpgill
Oct 30, 2013 07:52 AM
Alanmite
Dec 16, 2012 12:08 AM
