People with 38+mm offset rims
Old Mar 14, 2014 | 11:16 AM
p nut's Avatar
Would you mind posting up pictures of how far you rolled your fenders? I recently bought some new rims (15x6.5 Konig Feathers) and for some reason, thought the stock wheel offset was 45+, and I should be fine. Turns out it is 55+ and now it's rubbing like crazy. I did a minor fender roll, but still getting rubbing. Just need to know how much I need to bend the lip back. Again, pics would be great. Thanks.
Old Mar 14, 2014 | 03:13 PM
What size tires are you using?
You shouldn't be rubbing unless you're really low or have HUGE tires.
Old Mar 14, 2014 | 03:31 PM
p nut's Avatar
205/50/15's (Yoko S-Drive), so not much wider than stock size of 195/55/15.
Old Mar 14, 2014 | 03:48 PM
Are you lowered?
Old Mar 14, 2014 | 03:59 PM
p nut's Avatar
No, stock height. Every time I go over a bump, I can hear both sides scraping. Need to figure out exactly where its hitting.
Old Mar 14, 2014 | 04:50 PM
Texas Coyote's Avatar
The rubbing must be on the inner lining..
I have 205-50-16s on wheels with 45mm offset and no rubbing..
Old Mar 14, 2014 | 06:08 PM
p nut's Avatar
Thanks, Tex. You may be right. I'll have to check it out some more. Although we're talking 7mm difference between your rims and mine, so that could play a part as well.
Old Mar 14, 2014 | 06:51 PM
Yours really should not be rubbing.
Even a little. Your OEM suspension is probably incredibly blown.
Old Mar 14, 2014 | 06:57 PM
p nut's Avatar
I highly doubt it. I see no leaks and it only has 77k miles on it. I'll double check, though.
Old Mar 14, 2014 | 09:33 PM
p nut's Avatar
Ok, I *think* I found the culprit. It's the plastic bit sticking out by the screw head. I put some masking tape over it earlier today and when I got home, there were some rub marks on it. I'm going to try and dremel that down a little bit to see if it alleviates the rubbing.
Old Mar 14, 2014 | 11:46 PM
Hootie's Avatar
^^ Yep, that would be a good starting point. I would suspect trimming the black plastic down flush with the metal lip that the bumper butts to would be a good start... however...
If you want to verify prior to cutting either put some tape, chalk or white shoe shine/polish on the area for the bumper screw and test drive the vehicle. If it rubs away some of that marking then that is the culprit.
The first time I ran 205s, they nipped the rear bumper in that same location and I just let them wear down till they cleared. If you are rubbing up front, you should "pop" the fender liner over the metal tabs on the front fender and "squeeze/push" up the metal tabs to aid clearance.
Old Mar 15, 2014 | 01:37 PM
p nut's Avatar
Hootie, great minds think alike. Look at my post above yours.
I used a file to shave the plastic part down this morning. So far, no rubbing, but haven't gone over any hard bumps, either.
Worst part of this is, I trashed the inner lip pretty bad trying to bend them back, which apparently may not have been needed... I need to sand and spray some paint on them soon.
EDIT: Ok, so it looks like the little plastic tab was the culprit. Before anyone goes spending money on rolling fenders or doing a hack job on the paint like I did, file down that nub first!
Old Mar 16, 2014 | 12:47 AM
George02's Avatar
I have +25mm offset and I had to take that screw out and zip tie the bumper. It holds really well. GL
Old Mar 20, 2014 | 09:19 PM
hollywoodscott's Avatar
Im runnin 16x8 26offset with 215 40 16s.... I had to completely remove the rear tabs trim the bumper and strech n roll the fenders...
Old Mar 22, 2014 | 01:27 PM
devmail's Avatar
TireRack warns about that tab when buying Enkei RPF1s at 41 mm offset, so I think it's common. Glad it's fixed!
Old Sep 8, 2014 | 12:03 PM
p nut's Avatar
Just an update for those that may come across this thread in the future:
Since the last "fix," I was still getting some rubbing when going over a hard bump and/or carrying cargo/passengers. Admittantly, much better than before, but still was an on-going issue. I filed down the plastic lining of the bumper quite a bit and have done enough hacking to call it quits.
Currently, I am in the process of buying some stock 15" Civic wheels with a 45+ offset. I am hoping this will resolve it. If not, plan B (or is it C?) is to sell the 205/50/15 tires and go with 185/60's. If that doesn't solve it, I'm walking.
Old Sep 8, 2014 | 01:37 PM
Rollerboots666's Avatar
Run some camber and it will help the rubbing. Get some camber bolts and go maybe -1* to start and see if that helps. Are you rubbing in the rear? Idle so again shim the spindle plate to get about -1-1.5*.
Old Sep 11, 2014 | 04:15 PM
p nut's Avatar
Thanks rollerboots. I ended up just getting some new wheels. 45 offset and no more problems.
ccl088
Aug 1, 2011 09:41 PM
Azizul Zulzaha
Mar 22, 2011 01:01 AM
panda1314
Apr 28, 2009 10:37 PM
i dnt f!t
Mar 3, 2009 04:29 PM
tougerunner86
Apr 10, 2008 02:12 AM
