Strup Header Review
Old Mar 19, 2014 | 02:30 PM
PITFIT's Avatar
Strup Header Review
Well here it is folks....a review of the Strup Performance Upgrades 4-1 header. I noticed nobody seems to have reviewed it or used it?
Without comparing to other headers, I'd say this is an excellent value.
A couple strong points for this header -
  • Weld quality appears fantastic, no leaks,
  • Flange is rather thick, little chance of warpage.
  • Finish is shiny....ooh I love shiny things
Only weak point thus far is it doesn't have an option to mount to the stock vibration bracket at the transmission, although it doesn't seem to affect it, I'm sure other headers remove that as well.
Performance:
In terms of performance, mind you this is butt-dyno, this has had a positive effect. It seems to be a close copy of the DC header, and the performance should hopefully mimic it. The GREAT thing is the low-end seems just as strong as before (I'm assuming this was due to wise selection of the primary diameter). I was afraid to lose driveability in the lower rpms. The midrange is noticebly stronger , and the top end definitely has more room to breathe. Is a header going to blow your mind, no.....combined with my SRI, was it worth it? Definitely.
BTW - you may be able to find these floating around eBay, I won mine on best offer for $80.
Old Apr 1, 2014 | 10:08 PM
Rollerboots666's Avatar
Looks similar to the MR and DME header.
Old Jul 22, 2015 | 09:00 PM
devmail's Avatar
Couldn't pass this one up either, ordered one today. Sick of waiting for the Weapon R race to come back in stock plus it is 1/5 the price.
Old Jul 25, 2015 | 04:20 AM
Myxalplyx's Avatar
Great review and that is a GREAT price! Wow! Thanks for sharing.
Old Jul 30, 2015 | 06:37 PM
eightsixlife's Avatar
I'll have mine for sale soon, less than 500 miles on it. Selling because going turbo
Old Aug 1, 2015 | 09:14 AM
h8rsama's Avatar
Let me know plz
Old Aug 1, 2015 | 12:16 PM
devmail's Avatar
These are selling super cheap on eBay http://m.ebay.ca/itm/STRUP-4-1-EXHAU...882?nav=SEARCH
$69 + free shipping, these were originally $300!
Got mine yesterday
Old Aug 1, 2015 | 01:09 PM
domoMKIV's Avatar
Install it yet?
Any hardware included? Did you reuse your oem gasket?
Might order myself one of these if it works out for you.
Old Aug 1, 2015 | 04:25 PM
devmail's Avatar
I'm waiting to get another bung welded in for a wideband O2. I'll let ya know how it goes!
Old Aug 2, 2015 | 09:05 PM
h8rsama's Avatar
I couldnt resist XD
Well......i'll tell you later how it goes
Old Jan 4, 2016 | 03:31 PM
Jimmyjoejak's Avatar
For the guys who installed the Strup headers, was there any fitment issues?
Old Jan 4, 2016 | 03:53 PM
Desmond Lamar MacRae's Avatar
After reading this I guess they only make header for 1st Gen.
Old Jan 5, 2016 | 12:48 PM
h8rsama's Avatar
Nop, fitment was just right.
I needed a new gasket tho.
So far, so good.
At first i couldnt tell where the gains were but now is definitely in mids and some highs.
AND smoother in the low end car now can hold a gear going up in 2k rpm and feel good at it.
Im pleased with this
Note: Im using a FUJITA CAI, and recently i got this breathing windows on my bumper and it feels even better now with the air flowing better. So far, so good
Old Jan 5, 2016 | 02:59 PM
Did you guys find a way to mount to the stock vibration bracket at the transmission? Is it possible to add a bracket to the spring mount bolt?
Old Jan 6, 2016 | 01:12 PM
h8rsama's Avatar
I wouldnt know that. It was just a bolt on but i guess its all possible if you really need it
Old Jan 6, 2016 | 01:35 PM
the stock headers have the mount and most other headers I've seen also have it so I'm assuming it's something that's needed. So you guys just bolted it up and didn't bother to use the transmission bracket? Any side affect of not mounting it to the bracket? movement of the headers and stress load on the header bolts?
Old Jan 6, 2016 | 01:40 PM
h8rsama's Avatar
I pretty sure i didnt see any brackets. 5 bolts up, 2 down, no more. It is yours a gd? AT or MT?
Old Jan 6, 2016 | 01:57 PM
I have 2008 GD3 MT. The OEM headers has a mounting bracket on the bottom where it connects to the spring bolts. The Strup headers don't have this, but other aftermarket headers have the extra mounting hole like the OEM.
Old Jan 6, 2016 | 04:00 PM
h8rsama's Avatar
Bracket
I see what are you talking about. Oem header has a bracket in deed. But it is used for the heat cover and strut don't have it. Just forget about it. It's nothing transmission related stuff
Old Jan 6, 2016 | 05:16 PM
Yup, it has the 3 nuts for the heat shield but the flange that accepts the spring bolts also has another hole for the bracket that mounts to the transmission. The OP said this too.
"Only weak point thus far is it doesn't have an option to mount to the stock vibration bracket at the transmission, although it doesn't seem to affect it, I'm sure other headers remove that as well."
I'm just wondering if omitting this will cause any long term problems since now the header is only held by the header bolts and the connection to the cat.
