Place to order crush washers?
Old Mar 24, 2014 | 01:59 PM
MTLian's Avatar
Hello.
Can anyone recommend a place where I can order cheap crush washers? I know there are bags of 50 available from amazon but I what am I gonna do with 50?!
I know rockauto sells them also but they the shipping is expensive if you don't bundle it with other products. Thanks for suggestions!
Old Mar 24, 2014 | 02:11 PM
Texas Coyote's Avatar
I am obsessive about oil changes but have never replaced the copper washer when doing a change.. I anneal the one that came on my car in 2006.. Use a propane torch or the burner on a gas stove to heat it until it begins to glow, let cool and reuse.
Old Mar 24, 2014 | 02:17 PM
i only use honda filters and they usually come with new washers as a set.
Old Mar 24, 2014 | 02:23 PM
Black3sr's Avatar
Originally Posted by MTLian
Hello.
Why not drop by a Honda dealer? Like how many do you need? They can't be that expensive.
Old Mar 24, 2014 | 02:50 PM
3cg's Avatar
3cg
autozone's "help!" section has a variety pack
Old Mar 24, 2014 | 03:21 PM
MTLian's Avatar
They are like 1.50 before taxes. Probably about 2$. Ridiculous. It's a washer! Napa sells em for more than a buck a piece. I'd rather just get a little bag and be done with it but 50 is overkill!
Old Mar 24, 2014 | 04:04 PM
spreadhead's Avatar
I used to get filters (Honda Filtech!) from College Hills Honda Genuine Honda Accessories at Discount Prices - Authorized OEM Honda Accessories Dealer , washer is included. I have a Fomoto valve, so I don't use 'em anymore.
Old Mar 24, 2014 | 07:21 PM
MTLian's Avatar
Good call man. I would install a fumoto valve in a heartbeat but the undercarriage of my car scrapes over tons of snow and ice in the winter so I'm afraid of having a valve that sticks out from the pan.
I would definitely use Honda filters but I'd rather get something better quality for about the same price. On my next oil change, I'm installing some Mobil 1 extended life filters.
Old Mar 24, 2014 | 07:37 PM
Brain Champagne's Avatar
I installed a Fumoto valve and it doesn't stick down. Can also put a clamp on it so it's even less likely to be opened by running over something.
Old Mar 24, 2014 | 07:38 PM
Goobers's Avatar
You could just decide to use those washers elsewhere.
or... WASHER, DRAIN PLUG (14MM) - Bernardi Honda Parts and Accessories / WASHER, DRAIN PLUG (14MM) for HONDA |94109-14000 ?
I have the Fumoto valve and it doesn't scrape. I have more issues with other things scraping.
I'm on Swift Springs.
Old Mar 24, 2014 | 09:07 PM
jmsplitfyre's Avatar
Go to PartSource/CanadianTire, they sell 14mm washers in packs of 3.
Old Mar 25, 2014 | 12:52 AM
MTLian's Avatar
Yea but fumoto warns about the nipple type valve on low sports cars. My fit is neither but I drive over some crazy ice. I just couldn't bare the thought of my valve braking or opening. Montreal sucks with snow clearing in parking spaces. When I park my car is so crooked you'd think two wheels where on jack stands!
I checked your link and they want 9$ shipping to a US address for 5$ worth of washers. I might try at the hardware store like Home Depot. They must have loads of washers. As long as it's aluminum and reasonably thick it should do the job.
The crush washer they sell at Canadian Tire are the not so nice ones with a rubber ring around the middle. I've heard those are not as good quality as the aluminum ones. Napa used to see me those until a guy looked up my car in his computer and it didn't recommend that type of washer.
Old Mar 25, 2014 | 05:21 AM
Black3sr's Avatar
I still don't understand why you are trying to find cheap washers. Hell we only change our oil maybe once a year so whether you pay a buck or 5 for a bloody washer does it really matter?
Old Mar 25, 2014 | 11:00 AM
Re Fumoto- Just don't have it pointing down when you screw it in. Makes changing the oil a lot easier.
Old Mar 25, 2014 | 11:39 AM
Wanderer.'s Avatar
I just buy the 5 pack aluminum crush washers from Autozone/O'Reilly... it's like $2.50? I'm sure they have an equivalent store in Canada. Just get the ones for Honda plugs it's usually in the description, it's just the diameter that defines it.
There's nothing wrong with those washers with the rubber ring, just get those. I've had those on several cars without an issue and I actually never or rarely changed it.
Old Mar 29, 2014 | 10:07 PM
Goobers's Avatar
I dunno, maybe don't buy the nipple version?
In any case... The location is pointing almost straight back.
Could something damage it? Yes, if you backing up and ran over a signpost that sprung up under the middle of your car or something.
As long as you install it with the valve handle on the upside (add a washer! If needed), you're more likely to bash your oil pan before coming close to breaking the valve.
Once installed, it never needs to come off. So, if you used a washer to orient it as needed, that washer stays put, doesn't need replacing.
And yes, i have run over plenty of crap on the road... Hitting my subframe, muffler, exhaust pipe and who knows what else, but not the oil pan or the valve.
Fitmo
Jan 13, 2021 03:04 PM
white_FIT2012
Mar 27, 2014 04:07 PM
mtunofun
Oct 27, 2009 01:07 AM
quick92ciFit
Jun 12, 2009 06:55 PM
Rob22315
Jul 23, 2008 09:50 PM
