cyl. 1 misfire,again.
Old Apr 11, 2014 | 05:58 PM
SadieB05's Avatar
Hey folks! Seems I'm having reoccurring issue. Over 2000 r.p.m,no.1 cyl. misses. I have adjusted the valves,new plugs,switched coil packs. Have always used quality fuel.At 152K,my thoughts are cam wear,lifters,timing chain/tensioner.But some advise before throwing cash at the wrong idea would be great.I've owned this cutie since 8200 mil.and want to drive forever!
Old Apr 11, 2014 | 06:05 PM
kochsteven4's Avatar
I'm not sure if this will help but i had an integra and the same issue and i spent about 1500 bucks to try and fix it but the real issue was the dumbest thing i didn't check. Since you did new plugs i would make sure the spacing is correct because sometimes they say that the they are pre spaced and come out to be not spaced so i would just double check that. Also at 100k the timing belt is to be replaced so if you hadn't done that yet i would definitely look into doing that next. i hope this helps
Old Apr 12, 2014 | 06:47 AM
Carbuff2's Avatar
Sadie mentioned the timing CHAIN (not a belt). As long as the oil was changed on schedule, this should not be a problem at 150K miles. Bad timing chain tensioner would be noisy in my experience with other cars.
I always check plug gap before installation...have been "tricked" more than once by out-of-spec electrode gaps.
Cam wear should be a visual with the valve cover off.
I'd have a compression test done. If good, THEN change all the coil packs....
JM2C.
Old Apr 12, 2014 | 11:56 AM
Marrk's Avatar
^^What Carbuff said sounds good to me.
rossftn
Jan 14, 2024 11:40 PM
09FIT101112
Nov 25, 2012 03:55 PM
Jensen Healy
Apr 9, 2010 03:11 AM
CarDemon
Oct 28, 2009 02:23 PM
jim beam
May 4, 2005 11:16 AM
