check fuel cap message in maintenance window
Old Apr 16, 2014 | 04:27 PM
gizmodog's Avatar
today the maintenance window showing mileage, MPG & tripometer flashed a message:
check fuel cap.
checked the cap it was tight & the door was shut.
what gives?
anyone else had this occurrence?
GD
Old Apr 16, 2014 | 05:24 PM
painterguy's Avatar
Senior Member
Pretty common on all late model Hondas.
You either have a failing gas cap or it wasn't tight enough after refueling and the evap self check picked up a leak.
Old Apr 16, 2014 | 05:36 PM
gizmodog's Avatar
will keep an eye on it?
anyway to know if it posted a code?
an if so, how to delete it from the system?
thanx,
GD
Old Apr 16, 2014 | 06:41 PM
doctordoom's Avatar
Supervillain
Just take off the cap, put it back on, and then it goes away after a while. Could be a day or several days.
Old Apr 16, 2014 | 06:56 PM
gizmodog's Avatar
thanx...
gd
Old Apr 16, 2014 | 08:19 PM
kochsteven4's Avatar
if that doesn't work get a new cap, i wouldn't imagine them being that much. good luck
Old Apr 16, 2014 | 10:46 PM
Irishredfireman's Avatar
My father-in-law has a 12 civic lx and he got the same thing the other day. He isn't the most car savy guy. But he didn't realize on most cars you should twist it till you hear 3 clicks. However he said he stopped and tightened it again. I think he said it was after fueling the car. I remember in the good ole days when you would just throw a CEL and then you'd freak out and have to drive to autozone and have it read. Youngsters today got it so easy, with cars telling you whats exactly wrong on the Odometer .
Old Apr 17, 2014 | 12:26 AM
raytseng's Avatar
you can also wipe down the cap and the filler top to remove anything that might interfere with the seal.
To delete the code, sometimes they do not go away.
It is pretty easy to buy an OBDII reader that will come in handy. Nowadays, if you have a smart phone, the easiest and inexpensive method is to get a bluetooth obdII interface device then get either an iphone/android app to connect to it.
Nowadays autozone won't read your codes for free anymore in CA
Old Apr 17, 2014 | 09:42 AM
2012FitFan's Avatar
This has happened to me a couple of times. Both times I filled up the evening before it happened. The next morning the fuel cap message popped up. Most likely I didn't correctly tighten the cap. I make sure now to turn the cap until it clicks twice.
Old Apr 17, 2014 | 10:00 AM
I'm in NC but it's been a few years sense I've taken any car to have a code read there. So it's possible they don't here ether. Bluetooth OBD II scanners geez! I must be getting a little old.
CrystalFiveMT
Jun 24, 2016 11:15 PM
SkEEzY_GT
Jul 22, 2010 02:56 PM
smeister
Feb 19, 2007 06:40 PM
Daniel1975
Sep 21, 2006 12:12 PM
jack_90125
May 27, 2006 01:00 AM
