Automatic shifter light
Old May 19, 2014 | 11:51 PM
spreadhead's Avatar
Is the console shifter selector illuminated (does the gear selection light up)? Mine is not lit. Did it burn out or was it never lit. I think it was, but I could be wrong. Want to know before I remove the console.
Old May 20, 2014 | 12:17 AM
ikutoisahobo's Avatar
It is lit, yes. Only when the headlights are turned on though.
Old May 20, 2014 | 12:36 AM
spreadhead's Avatar
Thanks, I guess my bulb is burned out. Anyone know the bulb number?
Old May 20, 2014 | 01:07 AM
Not sure, I tried looking around. If you're gonna open up the console you might as well just pull the old bulb out and see what it is,
Old May 20, 2014 | 09:10 AM
spreadhead's Avatar
Would like to have the new one on hand to save time. Remove console, replace bulb, reinstall console without having to run to town, and possibly wait for a hard to find bulb.
Old May 21, 2014 | 05:30 PM
Scholzpdx's Avatar
I've got an 07 Sport auto with 143k. Mine doesn't light up at all. If someone finds a part number on the light, please post it here.
Old May 22, 2014 | 01:16 AM
spreadhead's Avatar
Don't know the bulb number and don't have it with me at the moment, but my stealership had it in stock for $3.
Old Dec 3, 2016 | 05:39 PM
frank438's Avatar
How do you open up the console to replace the bulb? Ours in our 2008 Fit just went out too, and I don't want to dismantle the whole console just to change one tiny lightbulb. Also, anyone know which fuse controls the bulb? Maybe it's just a blown fuse, which would be much easier to change than the bulb.
Old Dec 3, 2016 | 09:39 PM
doctor J's Avatar
The console has to be removed to get access to the bulb; it doesn't have a separate fuse
Old Dec 3, 2016 | 10:04 PM
frank438's Avatar
Dang, I was afraid if that. Would be too easy to make it accessible...
Can the grey oval shaped piece around the shifter itself (has the P, R, N, D, D1, etc. in it too) be removed or at least loosened? I would think logically this should come off far enough to change the bulb...
Old Dec 4, 2016 | 10:44 PM
Hootie's Avatar
The center console is easy to remove. 2 push clips, 2 screws, the auxiliary & accessory socket connectors and MAYBE the parking brake cover/lid if I recall correctly then it tilts up and out the way.
Old Dec 4, 2016 | 11:33 PM
frank438's Avatar
Thank you! I will have to try this next weekend if I get time.
Old Nov 27, 2017 | 03:38 PM
utsug's Avatar
anybody knows what is part number for this bulb? Thanks.
I found the part. there are two part numbers P/N 35505-692-003 and P/N 35505-TA5-A51. This is for GE8, not sure if its the same for GD.
http://www.bernardiparts.com/Honda/Parts-List.aspx
Ozray
Jun 14, 2019 02:19 AM
kbh
Dec 7, 2013 03:00 PM
alanchan
Mar 28, 2013 02:57 PM
Black01
Jan 8, 2011 10:56 PM
swingbyte
Mar 31, 2010 08:24 AM
