Sponsored by:
Sponsored by: CARiD
CVT relearn ???
Old May 27, 2014 | 03:44 PM
victorgarage's Avatar
CVT relearn ???
is there any prosess to relearn or recalibrate the cvt?
is it needed?
thanks
Old Dec 5, 2022 | 02:22 AM
Regz's Avatar
1. Reset the ECU by removing the negative terminal of the battery for about 5 minutes then reconnect it. 2. Ensure that everything is off or there is no electrical load to the car like stereo, lights, dashcams and ensure to close the door as well. Turn on the ignition for about 2-5 seconds then start the engine. Hold the RPM steady to 3,000rpm for 5 minutes. 3. After 5 minutes, release the gas pedal and let it idle until both fans (radiator & condenser fans) complete two cycle run. You can step outside the car, pop the hood and watch the fans till they complete the two cycles. 4. After two cycles of running for both fans, leave the engine running and turn on the AC for another 5 minutes. 5. After 5 minutes for the AC running, turn it off. You can idle the car or turn it off and its already relearned.
Hondarian
Feb 13, 2017 07:32 PM
sanosuque
Jan 26, 2008 03:23 PM
epin
Nov 19, 2007 06:13 PM
kwest2bee
Feb 5, 2006 07:28 AM
