2007 Fit sport automatic jerking
Old Jun 16, 2014 | 09:09 PM
skipole's Avatar
For the last 1/2 year or so, my car has been jerking at various times. It seems to happen most going uphill at a slight include around 60 MPH. I thought it might be an issue related to the transmission, but it sometimes would happen when the car wasn't moving, such as being stopped at a stop light.
I did notice that if the car seemed to be jerking when the car wasn't moving, and I put the car in neutral, the car would no longer jerk.
Now that it is warmer, I noticed that the car jerks much more (when not moving) with the air conditioner on. I turned the air off (and kept the fan on), and the jerking slowed down or even stopped.
I've had the car to the Honda dealer several times, and they haven't been able to reproduce the issue or figure out what the issue is.
Any suggestions?
Thank you,
Dennis
Old Jun 16, 2014 | 09:39 PM
DWils's Avatar
Have they checked the spark plugs and coil packs?
Old Jun 17, 2014 | 06:40 AM
skipole's Avatar
As far as I know, they did not. I have the car in the shop again on Thursday and I'll have them check.
Thanks!
Old Jun 17, 2014 | 08:40 AM
skipole's Avatar
I called the dealer. They said that if there was a misfire or a coil issue then the check engine light would go on. I suggested that maybe the check engine light is broken...
Would it have to come on if there were coil or plug issues?
Old Jun 17, 2014 | 09:15 AM
bargainguy's Avatar
Long shot: Bad engine mount. Might help explain why jerking happens when in gear but the car is not in motion.
Old Jun 25, 2014 | 02:20 PM
Takahiro's Avatar
Same problem; was the coil pack
Any suggestions?
Thank you,
Dennis
I had the very same issue, except it worsened rapidly, over a few weeks rather than six months. But every symptom you describe was the same. One of the coil packs needed to be replaced, and he's been running just fine since then. (Currently at 181k+).
Old Jun 25, 2014 | 02:36 PM
skipole's Avatar
Despite the fact that the dealer said it could not be a foil pack (because the check engine light wasn't on), it was. Fortunately, I had the car there at a time where they could replicate the issue.
They also said that a spark plug was bad and suggested I change them all out. Good thing they checked again because they were all good and they had all been replaced about a year ago.
Takahiro: I am looking forward to the 181k+. I am currently around 119k.
Old Jun 25, 2014 | 04:23 PM
jazzista's Avatar
Don't mean to sound too dumb by posting everywhere the result of my humble diy, but my car was very rough, with very low mpg and the ECU seemed to behave absurdely (from the O12, O22, LTFT and STFT my scangauge was measuring). Then I read to check and clean the EGR valve.
Well the car now is running really smooth. If you didn't yet check it, perhaps it's worth a try.
HTH,
Old Jul 8, 2014 | 02:44 PM
hqly's Avatar
How much did they cahrge you? Itemize amt would help me negotiaite my prices. I have the same issue!
Old Jul 8, 2014 | 02:45 PM
hqly's Avatar
HTH,
what are EGR valves?
Old Jul 8, 2014 | 03:00 PM
Fitguy07's Avatar
(EGR) Exhaust Gas Recirculation. Does pretty much what it sounds like. The valve allows exhaust gases to recirculate back into the combustion chamber to be completey burned.
If you want more info, click here - Exhaust gas recirculation - Wikipedia, the free encyclopedia
Old Jul 8, 2014 | 04:39 PM
ikutoisahobo's Avatar
Most likely coil packs.
gadfly
Feb 14, 2019 04:45 PM
Rebelee08
Mar 6, 2017 12:56 AM
Silvermelon19
Jul 24, 2015 12:33 PM
Ryan Coleman
Mar 26, 2014 01:58 AM
jgrosshans
Feb 10, 2013 05:16 PM
