Power question
Old Jun 26, 2014 | 03:43 PM
epijimenez's Avatar
Power question
Anyway to prevent the radio from powering off during ignition?
Have the HON BT35 Bluetooth model and it disconnects when going though the ignition.
Also, anyway to give constant power to the DC power outlet in the car?
I wanna be able to leave a small mp3 charging in the car.
Old Jun 26, 2014 | 04:01 PM
as for constant accessory power during ignition, i dont think so.
also the battery is small so it's best you dont drain it. your battery will last longer.
Old Jun 26, 2014 | 07:38 PM
spreadhead's Avatar
You can wire unswitched power from the battery to the power supply wire of the radio.
Old Jun 27, 2014 | 03:19 AM
DWils's Avatar
Like spreadhead mentioned as quoted below, you could also do the same for the auxiliary power port. Or you could just buy a new one and use an add-a-circuit/fuse to the fuse box in a fuse that receives constant power regardless of ignition position. On my USDM GD3 fuses 18 and 19 I think were constant.
Old Jun 27, 2014 | 11:57 PM
epijimenez's Avatar
How would I go to do this?
Old Jun 28, 2014 | 12:00 AM
epijimenez's Avatar
Well, I want the radio to be off if the car is completely off, because like kenchan mentioned I think constant power (even when the car is off) will kill the battery quickly... since the Fit does have a small battery.
RavenManiac
Dec 28, 2017 12:58 PM
CBX
Nov 26, 2015 02:24 PM
benlinus
Nov 21, 2007 12:36 AM
Balorn
Jul 21, 2006 05:58 PM
John W. Barron
May 4, 2005 04:44 PM
