How to Connect XM Radio
Old Jul 29, 2014 | 03:43 PM
SilverEX15's Avatar
I've put portable XM radios in several cars, but I can't see an easy way to get to the Fit's antenna connection. Have any of you installed an XM radio?
Old Jul 29, 2014 | 05:46 PM
15/SILVER/EXL's Avatar
SilverEX15,
I installed a Roady2 and placed the XM antenna right in back of the normal radio antenna which works great.
I have a picture posted under my screen name on the forum in this link-
https://www.fitfreak.net/forums/3rd-...-2015-exl.html
I think you maybe talking about only using the existing antenna? Not sure if this helps
Old Jul 29, 2014 | 06:26 PM
SilverEX15's Avatar
What I mean is getting the signal from the XM radio to the radio in the Fit. For other installations, I ran a wire from a modulator to the car antenna and from the modulator to the radio. How did you get the signal from the XM to the Fit?
Amazon.com : Audiovox XM XMFM1 FM Direct Adapter (Black) : Vehicle Audio Auxiliary Adapters : Car Electronics Amazon.com : Audiovox XM XMFM1 FM Direct Adapter (Black) : Vehicle Audio Auxiliary Adapters : Car Electronics
Where did you mount the Roady2?
Old Jul 29, 2014 | 08:39 PM
The Roady2 sendS the XM signal to the FM channel 88.5 and I then receive the XM stations over the car OEM radio. The Roady2 is not hard wired to the car unit. Hope this answers your question.
Cheers!
Old Jul 29, 2014 | 08:56 PM
SilverEX15's Avatar
Cheers!
Thanks. I forgot about that, since I had always used a modulator.
Old Jul 29, 2014 | 09:03 PM
NightScreams's Avatar
First thing I did was replace the crappy head unit with an aftermarket one that supports sirrius/XM. However I later found that the quality of XM radio was pretty bad, I think it's about 48 kbps so I dropped it.
Old Jul 29, 2014 | 09:24 PM
Interesting.....My XM Roady2 unit sounds great through my OEM radio...a vast improvement over just FM. FWIW...
Old Jul 30, 2014 | 08:01 PM
According to reviews it varies a lot according to different factors. but here's one example:
The best FM sound was obtained with the MD100 tuner and roof antenna. The NAD tuner and Godar antenna were both good but did not allow best reception or sonics. Sound quality is a toss-up with FM winning the battle for ultimate resolution and detail and XM taking points for consistency.
Either way it's all pretty heavily compressed, some XM stations were worse than others. Personally I have a 1200 watt system and C300 front speakers and a nice HU with time delay, XM sounds like crap on my setup.
Old Aug 2, 2014 | 06:31 PM
SilverEX15's Avatar
Today I connected the radio and tuned it to send the XM signal to my car radio on 97.1. So far, so good. I have the XM antenna sitting on the dashboard.
Old Aug 2, 2014 | 06:38 PM
Great! I installed my xm antenna (magnetic) right in back of my roof antenna and ran the wire hidden a the way to the front console where my Roady2 is. It made for a clean install. Just a thought.
Norman99
Jun 22, 2011 04:31 PM
GodSpeed
May 19, 2009 02:43 AM
orion42
Jan 23, 2009 08:54 PM
bigtoepfer
May 22, 2008 11:10 AM
SilverBullet
Dec 30, 2007 06:39 PM
