165/50/15 on 15x8
Old Aug 2, 2014 | 03:22 PM
Alvarooo90's Avatar
165/50/15 on 15x8
I'm going to be running this set up when I get my car back. Anyone have any experience with this amount of strech? I'm rubbing alot and I don't want to camber so I was forced to strech
Old Aug 2, 2014 | 04:08 PM
Fitguy07's Avatar
Let me ask. Why are you running an 8" wide rim? Did you get a deal on these rims or something?
Old Aug 3, 2014 | 11:34 AM
Alvarooo90's Avatar
I like the look
Old Aug 9, 2014 | 10:04 PM
Paulo107's Avatar
165/50/15...
Old Aug 11, 2014 | 09:54 AM
Wanderer.'s Avatar
That's a fairly standard stretch, i'm confused about what the question is though?
Old Aug 12, 2014 | 09:54 PM
solbrothers's Avatar
you should run camber
Old Aug 12, 2014 | 09:58 PM
Alvarooo90's Avatar
Just asking if anyone has had any experiences wether good or bad with stretched tires.
I'm running -1.5 camber up front and the 195's still rubbed so hopefully this will clear it up
Old Sep 10, 2014 | 10:56 AM
shottachris's Avatar
just watch out for pot holes they will bend ur wheel ive have the same set up
Old Sep 10, 2014 | 11:03 PM
2poler's Avatar
what is your fear with running camber in the front? With a proper alignment and general tire rotations there should be zero issues running around -3. I assume the rims are a +25 offset and this is one of the challenges. GD? and what suspension? If you have not done a pull and roll you will need to as well. As for as the stretch goes, you should be fine with general driving but I would not autocross them for fear of sliding off of the bead. I have a buddy running 19x11 with 235/40 19 with a big stretch and it works but he does not daily it. Beware curbs and fear potholes!
Old Sep 11, 2014 | 12:37 AM
Alvarooo90's Avatar
It was a good set up while it lasted. But it made the ride so horrible, hard as hell. Running 15x7 now and back to a 195 55 15
Green karma
19
Jan 8, 2013 11:53 AM
n00b_stat
Oct 1, 2011 06:08 PM
danger69
Sep 30, 2010 08:37 AM
chinkyy
Hawaii Community
Oct 17, 2009 01:44 PM
Illmatic07
20
Jun 12, 2009 04:16 PM
