2007 Fit thump
Old Aug 2, 2014 | 11:43 PM
Gumby73's Avatar
Red face 2007 Fit thump
Hello, I recently changed the clutch in my 07 Fit at 69,000 miles. Been on the road about a week and just developed a rhythmic thumping when I decelerate between 20 and 10 MPH. When I accelerate in that speed range no noise only when the engine is not driving the vehicle forward.
I put the vehicle back on the lift this evening and looked around and all looks well. Even ran it up to 20 and no thump. Took down back on the road and same scenario.....Help!
Thanks
Old Aug 3, 2014 | 04:46 PM
doctordoom's Avatar
Supervillain
Did you check that your axles are fully seated in the transmission? Distinctive click felt when the circlips seated? CV joints fully seated too - you pried (not pulled) them out of the transmission? Because it sounds different accelerating vs decelerating, I'd suspect the axles first. I'm guessing no sound when decelerating in neutral, only when in gear?
Old Aug 3, 2014 | 04:48 PM
doctordoom's Avatar
Supervillain
And any symptoms about when applying the brakes in gear? In neutral? You kinda have to use a process of elimination and narrow down the choices.
Old Aug 3, 2014 | 04:51 PM
doctordoom's Avatar
Supervillain
Also try all the above with the clutch engaged vs disengaged to rule out the clutch disc/pressure plate installation.
Old Aug 3, 2014 | 11:51 PM
Gumby73's Avatar
Thanks Doc.
I removed both CVs very carefully by prying not pulling. However when I put the back together the driver side CV closest to the transmission came out of the socket. I put it back in and figured all was well but maybe not???
In Neutral or with the clutch pedal depressed the sound seems louder than when I simply let it coast down in gear (decelerating). As soon as I apply a little power sound goes away. Also when decelerating as soon as I apply some brake pressure the sound goes away.
I sure appreciate your help!
Old Aug 5, 2014 | 03:34 PM
doctordoom's Avatar
Supervillain
No problem. I suspect it might be that CV joint or where the axle mates to the transmission. Basically, something to do with the axle or its joint(s). You might need to hold the axle vertical and pound it on the ground to get it fully seated. You might just need to backtrack and double check everything you did. That would be the best bet but it can be a pain too. Good luck!
Old_Liver
Jul 17, 2017 07:58 AM
tduffy
Jul 27, 2013 05:47 PM
jessicairene
Jul 18, 2013 12:50 AM
Mark94
Aug 2, 2010 01:21 PM
