A/C problem.
Old Aug 19, 2014 | 09:06 AM
Mikepfeiffer1's Avatar
A/C problem.
Hi guys first post here! Got a ge8 (2010 sport) about a month ago. My A/C was blowing on all 4 settings up until yesterday. Now it will only blow high on 4 this goes for heat as well. Any ideas?
Other than this minor issue I love my fit. Got a great deal on a super clean car.
Old Aug 19, 2014 | 09:40 AM
De36's Avatar
Old Aug 19, 2014 | 11:04 AM
yah, my 09 did that too 3-4yrs ago. had it fixed under warranty. check tsb.
Old Aug 19, 2014 | 11:49 AM
Originally Posted by De36
A hard install? Never really had to work on AC units in any car I've owned.
Old Aug 19, 2014 | 12:47 PM
De36's Avatar
It's behind the glove box. I don't know where exactly, but it's held in by x2 screws.
Old Aug 19, 2014 | 12:50 PM
De36's Avatar
Old Aug 21, 2014 | 09:43 PM
This is fantastic! Thanks so much!
Old Aug 22, 2014 | 01:54 AM
medbill's Avatar
Jinxed me, mine just went today on a long trip 3.5 hours each way. At least I still had AC. Appointment made at the dealer for next week since my 09 is still under warranty. Good luck with yours!
Old Aug 22, 2014 | 07:50 AM
De36's Avatar
Please let us know what ends ups of the repair.
Old Aug 25, 2014 | 11:50 PM
Might wait a month or two. The A/C blowing on a high setting doesn't bother me as much as the heat will. I like to stay warm but too much heat is uncomfortable.
Old Oct 1, 2014 | 09:16 PM
Bogus
Told you guys I would update you. Found the carfax and the blower mitor has been replaced before. I'm not gonna go to all that trouble and money until it stops blowing all together. Did tip the glove box done and it seems like a pretty easy swap.
Old Oct 2, 2014 | 08:56 AM
De36's Avatar
It's not the "blower motor" that failed. Its the "blower motor regulator" you need to replace.
Old Oct 5, 2014 | 10:20 AM
ive seen mixed comments on this. Will definitely look into it more.
Old Oct 5, 2014 | 05:12 PM
07hatchfit's Avatar
wouldn't it be the blower motor switch if it only works on high?
Old Oct 5, 2014 | 06:39 PM
Yeah but I read about a few guys just replacing the switch wasting 30 bucks and having to replace the motor and switch all over again.
Old Oct 5, 2014 | 08:53 PM
Kuro's Avatar
Just ran into the same problem and went to the Honda dealer with the TSB number 09-097 and they took care of it for free. I did call into Honda corporate first to get a case number to see if they can do it as a goodwill repair since I was out of warranty. I would try to call Honda first to see if they can help you get it fixed. Good luck.
Old Oct 5, 2014 | 11:39 PM
This is awesome thanks for the info!
Old Oct 6, 2014 | 09:43 AM
DrewE's Avatar
Typically, the switch is OK, but the resistor (or "regulator") is toast. There are three parts to the system: the switch, the resistor, and the motor. The switch selects various resistances on the resistor that are inline with the motor, the bigger the resistance the lower the blower speed. High speed bypasses the resistor altogether and sends the full power to the motor. Off, of course, breaks the circuit entirely.
Generally, the resistor dies by overheating and melting a fusible link in the unit. This can be because of age or damage to it, or a severely clogged cabin air filter (the resistor itself is in the ductwork to have some forced-air cooling), but most commonly on the Fit is due to a defective motor with a bad bearing, which causes it to draw more current than it should otherwise draw. If the motor is bad, replacing the resistor is not a long-term fix; the new one will die just as the old one did in comparatively short order. It's necessary to replace the blower motor as well with a new one (of fixed design/production). That's what the TSB is about, and many dealers will do it for free if you ask as it's a known, documented defect from Honda.
On some (domestic?) vehicles, the resistor and switch are integrated into the same unit, but I that's not the case with Honda. On other vehicles, particularly those with electronic controls, some sort of a solid state controller is used rather than a simple switched resistor bank.
Old Oct 14, 2014 | 04:55 PM
martinaMaine's Avatar
What does TSB number 09-097 mean. I have 41,000 miles and my blower motor and reisiter just went out.
Old Oct 15, 2014 | 06:32 PM
Kuro's Avatar
It means that Honda knows there is a problem but it was not a recall so that's why I called corporate 1st to see if they can help out since I was barely out of warranty by a couple months.
https://www.scribd.com/doc/26128795/...tor-TSB-09-097
Tim_Bracken
Oct 4, 2013 07:47 PM
pip_rocks
Jun 20, 2011 02:12 PM
EDU
Jun 12, 2011 08:49 PM
RevToTheRedline
Aug 17, 2010 08:57 PM
sandler
Jul 26, 2008 12:32 PM
