L13 and L15 Cylinder Head
Old Sep 11, 2006 | 04:34 PM
kimo's Avatar
Are both heads the same.
Old Sep 11, 2006 | 06:23 PM
wyy183's Avatar
The DSI and the VTEC are not the same head.
The L13 is DSI (someone correct me if I'm wrong!!) while the L15 is a VTEC.
The DSI uses 2 spark plugs/3 valves per cylinder and the VTEC uses 1 spark plug/4 valves per cylinder.
Old Sep 11, 2006 | 06:25 PM
kimo's Avatar
I think you are right.
Thanks
Old Sep 11, 2006 | 06:29 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
I heard somewhere that it is possible to use 2 plugs per cylinder on an engine.. is that correct? if so.. why would you wnt to do that?
Old Sep 11, 2006 | 06:31 PM
kimo's Avatar
My car is L13 (2 Plugs)
Old Sep 11, 2006 | 06:38 PM
wyy183's Avatar
The DSI engine has a swirl flow through it where the plugs fire off one after the other to completely burn the fuel/air mix.
It is supposed to be quite a bit more efficient.
You can read about it at:
http://asia.vtec.net/Series/FitJazz/lseries/index.html
(This also gives you correct information rather than my poor memory!!)
Old Sep 11, 2006 | 07:43 PM
AJ PwR Jr.'s Avatar
Former Vendor
The L13A is a 8V engine. L15 is 16V.
Old Sep 17, 2006 | 02:56 AM
Kostas's Avatar
1.3 (1339cc) DSI works with 2 valves per cylinder
1.2 too.
Mehmet0001
Jul 28, 2018 08:31 PM
Sid 6.7
Apr 3, 2017 10:50 PM
jcroucier
Aug 23, 2016 04:46 PM
zrkd51
Jun 4, 2015 06:15 PM
Maty J
Jul 10, 2013 02:29 AM
