3rd Gen GK Specific Fit Interior Modifications Sub-Forum Threads discussing interior modifications for the 3rd generation GK Honda Fit
$11 DIY Cargo Cover
Old Oct 4, 2014 | 09:44 PM
NotBlake's Avatar
$11 DIY Cargo Cover
Per Rottboy's request, here is the $11 DIY Cargo Cover that should be easily repeatable anywhere in the US.
Not wanting to shell out $200 for what was essentially a cloth-covered piece of fiberboard. I decided to get a $11 sheet of fiberboard and make my own damn cargo cover.
What it is:
-Cheap
-Effective
-Relatively Subtle
What it isn't:
-Factory
-Pretty
Step 1: Go to Michael's, walk past the section with regular foam core boards, and head straight to the custom framing department. Tell the nice lady at the counter that you need a huge sheet of black foam-core board. They have a 40"x60" sheet for $10 and change plus tax. This is large enough to give you a template cut and a final (bonus: this board is large enough to show a friend just how versatile your little hatchback is).
Step 2: cut a rectangle from the foam core that's about 45"x14" with a sharp new box-cutter and start whittling it down bit-by-bit to get it to fit in the cargo cover tray. This will take some time and your entire vocabulary of swear words.
Step 3: If you are as useless as I am, you will have some gaps that need filling where you cut too much away. tape some cardboard pieces in place to get a nice template.
Step 4: place your completed template on top of your fresh piece of board and cut a nice clean piece from your template.
Step 5: test fit and trim as necessary. Mine fit very snugly the first time - yay.
I put a flashlight below the cover so you can see that there are still some small gaps, but with my 40% tint and no light in this bay, it would not be possible to see anything through these gaps. Obviously the more patient you are, the cleaner your result will be. I am not a patient man.
The board is plenty rigid enough to hold its own weight, but not much more. It might not be for you, but this is functional enough to keep curious eyes off my precious cargo for now until the price on the OEM piece comes down.
Hope this helps.
-Blake
Old Oct 4, 2014 | 09:57 PM
BLXFITTY's Avatar
ghetto! I like it
Old Oct 4, 2014 | 10:14 PM
ashchuckton's Avatar
Nice work Blake. Sure beats what Honda wants for one.
Old Oct 4, 2014 | 10:36 PM
NotBlake's Avatar
Thanks, I'm considering doubling up the thickness and wrapping it with some cheap black interior fabric and just being done with it.
Old Oct 4, 2014 | 10:52 PM
tmport's Avatar
Nice DIY! But this just reconfirms how tacky Honda is for not including this with the car. I can't think of another hatchback in the subcompact/compact class that doesn't come standard with a cargo cover.
Old Oct 4, 2014 | 11:09 PM
DWils's Avatar
This has to be the funiest DIY I have read in a long time. Thanks not only for the humor, but also the information.
Old Oct 5, 2014 | 12:43 AM
bbigmouthh's Avatar
I love that . xD
Old Oct 5, 2014 | 04:16 AM
JFit123's Avatar
Excellent show and tell! Love it!
Old Oct 5, 2014 | 04:49 AM
noripwr's Avatar
Awesome DIY! With some tape maybe Velcro and strings, you can even attach the end of the strings to the tail gate so the cover would raise as the tail gate opens up!
Old Oct 5, 2014 | 06:24 AM
Ex-MA Hole's Avatar
I had built one for my 2010 using strapping. It cost a bit more than yours, but it was somewhat weight bearing- my old Wheaten Terrier would sit on-top of it back there on rides. I liked the strapping as I could do one piece at a time (I'm a perfectionist). I ran a piece under and opposite (following the direction of the car) to attach them to underneath. I even put hinges 2/3 of the way back so mine could open.
I tried to spray paint it black, but the paint looked poor on the wood, so I covered it with a towel (stapled to it). If I were to do it for my 2015, I'd buy a can of paint and a roller and brush and do it right.
Old Oct 5, 2014 | 09:12 AM
dpmason's Avatar
An inspiration!
Old Oct 5, 2014 | 10:43 AM
cheesewhiz's Avatar
Inspiring to say the least ... both reasonable and innovative, and FUNNY!
Well done, Thanks!
Old Oct 5, 2014 | 11:06 AM
NotBlake's Avatar
UPDATE: I'm happy to report that when viewing it from the outside or even from inside the passenger compartment, it's pretty impossible to tell that it doesn't belong there and you definitely can't see anything past it. You'd only really know it wasn't factory if you opened the hatch.
This will totally work until Honda come to their senses on the OEM cargo cover.
Old Oct 5, 2014 | 02:52 PM
15BlkPrl's Avatar
Nissan Note
Ford C-Max
Mazda2
Chevy Spark
Old Oct 5, 2014 | 08:40 PM
fibrepunk's Avatar
Nice! I will definitely do this when I pick up a Fit. $11 vs $200, easy decision!
Old Oct 10, 2014 | 08:22 AM
Bama3Dr's Avatar
Nice job! I think it looks pretty good myself. If you wanted to make it stiffer you may be able to glue some wood strips to the bottom lengthwise to brace it.....just an idea.
-Dustin
Old Oct 11, 2014 | 04:18 PM
zerodragon118's Avatar
I am working on this thanks for the idea I wqs about to buy the oem one but then saw this post and I am thinking I can do thins
Old Dec 30, 2014 | 10:00 AM
tbFit's Avatar
Thanks for the tips and inspiration. I paid $15 with tax for the 40x60 sheet and made a cardboard template first, cut to shape with a minor amount of trimming, added some gaffers tape to the perimiter and installed.
I think it came out pretty nice and it wedges in nicely without any velcro. Just bend slightly in the middle up or down to remove and chuck out of the way for the larger costco runs.
I have enough left over to make another one in a few years if this one gets dinged up or damaged.
Old Jan 3, 2015 | 12:49 PM
GotFitB13's Avatar
This is great, I'll probably make one of these, too. Does anyone know if the OEM cover is retractable? The one we had in our Forester was great because of that feature. I would only even consider the Honda one if it was retractable. I've seen it for around $160 on one of the OEM accessory websites, but $15 is way better than $160. Thanks for the guide, I think it will match my front liners wonderfully.
Old Jan 4, 2015 | 05:35 AM
Black3sr's Avatar
Curious, does it help quieten interior as well?
