rotor thickness
Old Oct 21, 2014 | 06:43 PM
swell6's Avatar
rotor thickness
How do you measure rotor thickness on the fit? There is a "cover" on the inside of the inside rotor that doesn't allow for the old "coin and ruler/tape measure" trick. Any ideas?
Old Oct 21, 2014 | 07:47 PM
Wanderer.'s Avatar
I used a micrometer caliper. I thought that's what everyone did?
Old Oct 21, 2014 | 07:57 PM
swell6's Avatar
In order to use a micrometer caliper, you must first own a micrometer caliper!
Also, how'd you make space in between the rotor and the piece of metal/plastic? that is on the inside of the rotor?
Old Oct 22, 2014 | 07:58 AM
Carbuff2's Avatar
I pivot the caliper out of the way. That gives you a nice spot to measure.
Old Oct 22, 2014 | 04:40 PM
Wanderer.'s Avatar
Go buy a mic, if you plan to do brake jobs the rest of your life it's a good investment so you don't have to monkey around with homebrew stuff. They're not that expensive.
If you use a mic you only need a very small section to access, there is room, I think it's right in front of the caliper, where you can squeeze it in there. Just poke around, there's a spot you can use.
Old Oct 22, 2014 | 08:23 PM
Carbuff2's Avatar
For nine bucks (USD) this would do the trick.
Digital Thickness Gauge
Gotta love Harbor Freight when you need tools you won't re-use everyday.
Old Oct 22, 2014 | 08:29 PM
Wanderer.'s Avatar
^Exactomundo
Though I regret purchasing the $5 battery quick disconnect for the other car from HF which broke at a very inopportune time.
Their tools have all worked fine for me though since, like you said, I don't use them every day.
GotFitB13
Aug 21, 2016 04:31 PM
Hasafraker
Dec 28, 2014 10:20 PM
Stephano Drakovich
Nov 4, 2014 09:31 PM
swell6
Oct 26, 2014 07:11 PM
QuackXP
Feb 15, 2010 04:48 PM
