DRL inquiry
Old Oct 28, 2014 | 06:21 PM
mr_RogerWill's Avatar
DRL inquiry
which wire do i tap into to get the low beam wattage the halogen bulb would get? if it matters, i have HID's installed
Old Oct 28, 2014 | 09:03 PM
DrewE's Avatar
I don't quite understand what you're asking exactly.
The DRL system I think uses the high beam filaments, running them at a reduced power level (using a switcher sort of a circuit, producing a fairly high frequency square wave rather than a steady DC voltage). In general, a HID setup does not react nicely when powered in that way. Do you have some sort of relay or separate input for DRLs? Or are you wanting to put in separate DRLs that aren't the HIDs? Or are you just wanting to disable them entirely?
Disabling is most easily done by pulling the appropriate fuse; a quick search here should reveal the right one if it's not obvious from the manual.
Old Nov 2, 2014 | 04:57 PM
i have HIDs installed, but the DRL function didnt work with the bulbs so i pulled fuse 8. but since the DRL function kept activating when i put the parking brake down, i figured there was a wire i could splice into to run to fog lights or whatever i choose to install for DRL; just looking to see if anyone knew which wire it was
SteveKeez
Feb 1, 2015 09:55 AM
Mr.Hollow
Sep 1, 2014 07:41 PM
Akwarr
Apr 27, 2013 09:35 PM
royalflush313
Mar 19, 2009 10:37 PM
fitster
Jun 6, 2008 04:24 AM
