cheap throttle body upgrade, from 50mm(stock) to 55mm for gd3 01-07 fit
Old Jan 23, 2015 | 01:09 AM
cra-z's Avatar
Thumbs down cheap throttle body upgrade, from 50mm(stock) to 55mm for gd3 01-07 fit
2006-2011 honda civic base model r18 motor's throttle body is a direct bolt on and seals on the same rubber gasket seal , can be easily found at a local wrecker for within $25-$50 , i have a crz and adapted it to my intake manifold through a different means , but i thought i'd share this with the gd3 owners out there
the coolant fitting angles on the throttle body can be altered with a propane torch and a deep crescent wrench to the desired angle in order to fit your stock coolant hoses
here are links : for the manifold pic : of the r18
[IMG],http://9thcivic.com/gallery/albums/engine-mods/2gtpuhg.sized.jpg[/IMG]
Old Jan 29, 2015 | 09:11 PM
derykisonder's Avatar
Nice to see a review on this actually. But actually if you have a crz and the ge8 and the crz have the same intake manifold and throttle body I believe.
Can you take a picture of the R18 installed? I've been wanting to see pictures.
Old Jan 31, 2015 | 02:11 PM
cra-z's Avatar
the r18 throttle body is a direct bolt on for a gd3 , but for a ge8 and a crz you need to make an adapter plate
also you may need to change the angles of the coolant fittings with a propane torch and a crescent wrench to the correct angle for your application
Old Dec 1, 2019 | 06:35 PM
Jonnyc's Avatar
Throttle body spacer
I had my gd3 throttle body bored from maxbore and just installed a tbs from bloxsport (EBAY),its for a civic and fits perfectly so far no codes but only have about 20 miles on it,
Desmond Lamar MacRae
May 8, 2022 01:49 PM
Myxalplyx
Jun 26, 2015 09:59 PM
HardCorpsFIT
Jan 27, 2011 12:32 AM
im the fit
17
Sep 17, 2009 11:19 AM
DrKelso
Nov 4, 2008 05:23 PM
