16x7 tire size...
Old Sep 24, 2006 | 03:50 AM
simons2k's Avatar
16x7 tire size...
What's the widest you can go with 16x7s?
I've searched and it looks like a 205 is what people are running with this setup.
Old Sep 24, 2006 | 06:26 PM
MINI-Fit's Avatar
The Fit Sport comes with stock 15" rims and 195/55-15 tires. The outer tire diameter is 23.4".
For 16x7" rims and for an outer tire diameter of about 23.5"
205/45-16 fits rims 6.5-7.5" wide 23.2" outer tire diameter
215/40-16 fits rims 7-8.5" wide 22.8" outer tire diameter- see BF Goodrich g-force sport (ultra High Perf Summer tire at Tirerack.com)
340 treadwear AA traction 25 pounds $77 each special price.
215/45-16 fits rims 7-8" wide 23.6" outer tire diameter- see Dunlop Direzza DZ101 (ultra High Perf Summer tire at Tirerack.com)
300 treadwear A traction 21 pounds $113 each.
Tirerack.com test result comparing Direzza with BFG g-Force sport
http://www.tirerack.com/tires/tests/...%3D145WR6DZ101
If you have lots of potholes in the roads of your area try the 45 series tires.
Old Sep 25, 2006 | 03:14 AM
simons2k's Avatar
Right on! Thanks for the info.
Old Sep 25, 2006 | 03:20 AM
simons2k's Avatar
I'm going to try 215/45's.
Old Sep 26, 2006 | 08:58 PM
P1!'s Avatar
P1!
i run on 195/50 on mine
Old Sep 26, 2006 | 10:40 PM
JDMish's Avatar
195/50 seems to be the best setup for the fit. We've had the 205/45's on there and they rubbed like crazy.
the 195 gave it that extra bit of clearance by the outer fender.
Old Sep 27, 2006 | 12:34 AM
MINI-Fit's Avatar
For 205/45 the rubbing might be related to wheel offset. Closer to +45mm would be safer than anything less than +45mm.
Wheel alignment with more negative camber would help a little and the rim width would be a factor. The wider the rim the more the tire will fit wide even with a 195mm tire vs 205mm tire.
Old Nov 10, 2006 | 11:15 PM
murky's Avatar
Just got my Enkei J10's on today (16x7 +42).
The dude I ordered them from had Falkens put on them (don't remember specifically which). When driving home, I felt a teeny bit higher off the road, and the brakes felt a little "weaker."
Got home and looked at the sidewall: 205-50/R16. Bigger by 0.7" diameter, and 60mph on the speedo = 61.7mph actual... but they visually fill the wheel-well REALLY nicely... and no rubbing.
Thoughts?
Old Nov 10, 2006 | 11:18 PM
mwr's Avatar
mwr
If the speedo error doesn't bug you and you like how it looks then I guess it's OK. I'm still pretty chicken about rubbing and think I may go 195/50-16 when my wheels show up.
Old Nov 11, 2006 | 12:44 AM
ASquared150's Avatar
Thoughts?
Thought: Pics!
Old Nov 15, 2006 | 12:03 PM
murky's Avatar
Originally Posted by ASquared150
Thought: Pics!
I lied.
Or, more specifically, I did finally experience a little rubbing. It was at a high-speed, and the suspension pretty much bottomed out due to a big dip in the road. It sorta irked me, but i'm not worried.
Old Nov 16, 2006 | 09:15 PM
STTICH's Avatar
50 seems too chunky.. 45 is perfect i'd say.
Old Nov 23, 2006 | 03:01 PM
Benggolf's Avatar
Just installed 205/45 x 16 Toyo Proxes 4 on 16 x 7 Emotion CR Kai wheels (+35 offset) on stock suspension. Looks great with no fender rubbing (yet). I originally ordered a +44 offset, but no luck.
Looks like problems might surface should I lower the suspension. Looking into an Eiback "Pro-Kit".
Any comments/suggestions from FiT gurus out there? TIA.
Old Nov 24, 2006 | 03:57 AM
ap12na2's Avatar
^^^Benggolf is your car lowered? if so how low and what type of suspension?
Old Nov 24, 2006 | 09:39 AM
Benggolf's Avatar
Ap12na2, suspension of the car is still stock; no problem except when going over speed humps with passengers at rear seats. There is a slight contact between rear tires and fender lips.
Looks like I will need to roll the fenders if I decide to lower the car....thinking about the Eibach Pro-Kit.
DigitalDude65
Jun 19, 2013 06:00 AM
Splater
Mar 15, 2013 12:51 AM
glong
Jan 20, 2013 11:35 AM
kdean101
Sep 16, 2011 03:19 AM
geepondy
Jul 19, 2008 03:44 PM
