K20 in a FIT??
Old Sep 26, 2006 | 06:21 PM
POPiPOP's Avatar
Exclamation K20 in a FIT??
Is it possible to swap a K20 type S, in a Fit? If so, how much will it cost approx.
If not, wich motor is it possible to swap??
Old Sep 26, 2006 | 06:31 PM
aallbbeerrtttttt's Avatar
been there done that
www.n1motoring.com, owner is Norm, N1Concepts on here
Old Sep 27, 2006 | 06:32 AM
blackgd3's Avatar
Senior Member
Any updates on the car albert?
Old Sep 30, 2006 | 02:54 PM
TotallyFit's Avatar
I see you guys have the B18c engine for sale.Do they fit into the Fit?
Old Oct 7, 2006 | 11:13 PM
07TaffetaFit's Avatar
better question, instead of paying an immense ammount of money on a K20, which most people can't afford. Why doesnt someone do some research into swapping a D16/ZC/B16/B17 etc motor. Alot of those motors you can get for alot cheaper and still make really good power with...I had a D16Z6 SOHC VTEC motor in my 91 CRX and with i/h/e and bullfrog cams I was making 145whp. As light as the CRX/Fit are, 145whp is plenty.
Old Oct 7, 2006 | 11:30 PM
Ricepuddin's Avatar
Father of the Wasteland
Dseries and ZC, y do that. B16 and B18 maybe the Rseries.
Fits arnt as light as the CRX.
Old Oct 7, 2006 | 11:58 PM
MINI-Fit's Avatar
Talking
I wonder what kind of gas mileage you get with a K20 engine in a FIT?
K20A
Found in:
2002-2005 Honda Civic Type-R (EP3)
2001-2006 Honda Integra Type-R(DC5)
Displacement: 1998 cc
Compression: 11.5:1
Power: 220 hp (162 kW) @ 8000 rpm
Torque: 152 ft·lbf (206 N·m) @ 7000 rpm
Redline: 8500 rpm
K20Z3
This inline-4 cylinder internal combustion engine is found in the redesigned Honda Civic Si. It has a aluminum block with aluninum heads, and a bore and stroke of 86 mm*86 mm, resulting in a 2.0 Liter displacement.
Found in:
2006 Honda Civic Si
Displacement : 1998 cc
Compression : 11.0:1
Power: 197 bhp (147 kW) @ 7800 rpm (sae NET Rev 8/04)
Torque: 139 lb·ft (189 N·m) @ 6200 rpm (sae NET Rev 8/04)
Redline: 8000 rpm
Old Oct 8, 2006 | 12:37 AM
jbrisson's Avatar
Originally Posted by MINI-Fit
K20Z3
Found in:
2006 Honda Civic Si
Redline: 8000 rpm
Hey....I have one. And pssst...between you and me, they're actually underrated a bit . Actual output is about 206hp-210hp at the crank. Some of us have been dynoing between 188whp-195whp on the same dyno's Crazy...
Old Oct 8, 2006 | 02:27 AM
Ricepuddin's Avatar
K20A
Found in:
Compression: 11.5:1
Redline: 8500 rpm
K20Z3
Found in:
2006 Honda Civic Si
Redline: 8000 rpm
stay away from the z if you dont like drive by wire
Old Oct 8, 2006 | 02:29 PM
jbrisson's Avatar
I'm presuming you're talking about the rev hang. Honda has released a TSB for a reflash for most earlier model 06 Si's that doesn't quite eliminate the rev hang (emissions purposes), but can allow the car to drive much smoother. Quite honestly, not a whole lot of people complained about it before, but even less are complaining now. My car's pretty smooth.
Old Oct 8, 2006 | 10:48 PM
Stevens24's Avatar
if you are sweating mileage I wouldn't do an engine swap.
Old Oct 18, 2006 | 03:26 PM
minidriver8's Avatar
28.7 MPG with a K20a3........
did i win?
xcsp800
Apr 6, 2011 12:57 AM
hogwylde
Nov 26, 2010 06:53 PM
07TaffetaFit
59
May 4, 2010 12:09 AM
GD3-Fit
30
Jun 8, 2008 05:36 PM
Zadfz
23
Jun 14, 2007 07:38 PM
