Erratic Gas Gauge
Old Sep 29, 2006 | 01:12 PM
FrogDaddy's Avatar
Erratic Gas Gauge
I noticed this a.m. when I first started up the fuel gauge it was at E and the light was on. This is all fine and normal and I don't have issue there. But, then after about driving a couple of miles needle inched away from E.
Light was still on. First time I've noticed this when reaching E.
I would expect it to reach E and light be on that it will stay at E or lower.
So I continued to drive until it reached E again the filled up. It took over 10 gallons. I typically fill 9+ gallons since I was used running to station as soon as I saw light and it was at E.
Only thing I can think of is that light comes on and I was on an incline which put it at E ????
Anyone else?
Old Sep 29, 2006 | 01:20 PM
garett's Avatar
I would have to agree that your car being at an incline is what caused the guage to be inaccurate.
Old Sep 29, 2006 | 04:40 PM
doctordoom's Avatar
Supervillain
yeah nothing to worry about. only if it goes from empty to full or something like that, then you should get it checked/fixed.
Old Sep 29, 2006 | 08:59 PM
FondaFit's Avatar
I've seen the needle inch back up a little even on flat ground (which is pretty much all we have here), and I think when the tank is really low vapors build up enough to change the pressure and move the float. After a few miles the needle dropped back down and the low fuel indicator came back on. It seems to light up when the fuel is down to a little over two gallons (about 8.5 - 8.8).
Old Sep 29, 2006 | 10:44 PM
Spule 4's Avatar
If it flickers back and forth or, as above, goes empty-full, then there is a problem. Inclines do this also, my entire property is on a hill, so I notice the same.
Old Sep 29, 2006 | 11:04 PM
Fray Adjacent's Avatar
Senior Member
Incline = inaccurate gauge reading. Happened in every car I ever had.
Old Oct 2, 2006 | 11:16 AM
nexus4400's Avatar
I always fill up my tank when its 1/4 empty and never run it dry to E. I think its good to have some gas to cool the pump.
Brain Champagne
Sep 16, 2018 01:55 AM
fitchet
Jan 27, 2017 03:20 PM
DeltaBond
Jul 23, 2013 12:20 PM
InternDoc
Aug 17, 2008 07:55 PM
yeeman
Feb 6, 2008 05:31 PM
