Erratic Gas Gauge
Erratic Gas Gauge
I noticed this a.m. when I first started up the fuel gauge it was at E and the light was on. This is all fine and normal and I don't have issue there. But, then after about driving a couple of miles needle inched away from E.
Light was still on. First time I've noticed this when reaching E.
I would expect it to reach E and light be on that it will stay at E or lower.
So I continued to drive until it reached E again the filled up. It took over 10 gallons. I typically fill 9+ gallons since I was used running to station as soon as I saw light and it was at E.
Only thing I can think of is that light comes on and I was on an incline which put it at E ????
Anyone else?
Anyone else?
I've seen the needle inch back up a little even on flat ground (which is pretty much all we have here), and I think when the tank is really low vapors build up enough to change the pressure and move the float. After a few miles the needle dropped back down and the low fuel indicator came back on. It seems to light up when the fuel is down to a little over two gallons (about 8.5 - 8.8).
