Hesitation from park to reverse
Old May 5, 2015 | 08:39 AM
MsFit's Avatar
I have been having significant hesitation when I go from park to reverse. Seems to take a few seconds for the transmission to engage. So much so the car would roll back if I did not have my foot on the brake. Anyone having this type of issue?
Old May 5, 2015 | 08:46 AM
FitfulKenny's Avatar
I didn't notice but will check later. You're parked on flat level ground?
Old May 5, 2015 | 08:53 AM
MsFit's Avatar
I am parked on pretty level ground. I first noticed it happening in my garage. I do not seem to have any other problems. I will check if it happends in drive later tonight. It is very evident from park to reverse in the morning on my way to work. Thanks for the response!
Old May 5, 2015 | 09:11 AM
I'm not observing that problem...you're driving automatic yes?
Definitely check again and I would bring it in if it is evidently still happening.
G'luck.
Old May 5, 2015 | 09:40 AM
MsFit's Avatar
I am sorry, yes it is automatic.
Old May 5, 2015 | 04:04 PM
FitFolksinger's Avatar
Having gone through a complete CVT failure on my EX I'd say with those symptoms you should take it to a dealer and have them take a look, even if the 'R' light showing reverse isn't flashing. At least you will have started a dialog if something worsens.
Old May 20, 2015 | 09:23 AM
Sham24's Avatar
I've seen the same thing on my LX automatic. Putting the car in drive kicks in immediately, but there's a several second lag when I put it in reverse - the gas just revs the engine and the transmission acts like it's totally disengaged. Is this not normal? I just wrote it off as something about CVTs until I saw FitFolkSinger's comment.
Old May 20, 2015 | 09:35 AM
Ex-MA Hole's Avatar
I get the same thing. I sort of attributed it to the computers processing what was happening.
Old May 21, 2015 | 06:45 AM
GoBucky's Avatar
I get a short delay shifting out of Park and into either Reverse or Drive. Its mildly annoying but I'm guessing its normal for the Fit.
Old May 21, 2015 | 12:56 PM
gusvera's Avatar
Yep, same in my car, think it's normal.
Stoli124
Apr 13, 2015 12:25 PM
chubbs899
Oct 22, 2014 04:37 PM
8strung
Aug 15, 2014 02:49 PM
07FitSBOM
Feb 15, 2009 11:44 PM
loud_tiger
Jun 25, 2007 12:05 AM
