Grinding sound when going into reverse on MT EX
Old Apr 13, 2015 | 01:27 AM
Stoli124's Avatar
So I've noticed that when I shift into reverse while the car is already rolling backwards the I get the sound of gear grind. Is this something others are experiencing?
Old Apr 13, 2015 | 06:47 AM
rodney's Avatar
i do not think i ever tried to put it into reverse while moving. knowing the way fwd transmissions work internally, i wouldn't be surprised there isn't a ton of racket when trying to do this.
you should stop, then put it into reverse.
Old Apr 13, 2015 | 08:07 AM
GoBucky's Avatar
Just curious, but why would you already be moving backwards before putting it in reverse? As Rodney said, just make sure you're stopped before shifting to reverse. Same thing in the other direction, as you're backing out of your driveway you should always make sure you're completely stopped before shifting from reverse to drive.
Old Apr 13, 2015 | 09:42 AM
Uncle Gary's Avatar
Just like every other manual transmission in the known universe, there's no synchromesh on reverse gear. That grinding is nature's way of telling you not to shift into reverse while moving.
Old Apr 13, 2015 | 11:53 AM
Wanderer.'s Avatar
^Yeah, this
You shouldn't be going into reverse unless you're stopped, that's true for all manuals for the above reason, but I think these transmissions are even less forgiving than a lot of other cars I've driven as far as how much you can actually be rolling before it grinds.
Old Apr 13, 2015 | 12:25 PM
Stoli124's Avatar
Yeah I did some more research and found that the reverse on Honda mt transmissions is a straight cut gear with no sychros so that would explain all the problems. The only reason i asked is my driveway is slanted so to back out I rarely need reverse but sometimes when I have to stop cause a car is passing I'll go to slide it into reverse. Now I know that before I pull off the ebrake to already be in reverse
azkikersfit
Mar 20, 2015 02:02 PM
chubbs899
Oct 22, 2014 04:37 PM
8strung
Aug 15, 2014 02:49 PM
belfastcowboy
Sep 24, 2010 05:07 PM
mattd00b
May 6, 2006 04:27 AM
