Noise coming from manual tranny
Old May 8, 2015 | 08:02 AM
trinisir's Avatar
Hey guys,
It's probably a bearing, but I don't know which one. Essentially, when I engage the clutch, it stops, when I disengage it comes back. Any one know which bearing or bearings, in the gearbox need replacing? Thanks.
Honda Car Parts / Choose by Model / Genuine Honda Parts | Honda Cars | Honda Motorcycles | Honda Power Products | Lings Honda
Old May 8, 2015 | 09:37 AM
DrewE's Avatar
My first guess would be the clutch release bearing.
I'm not an expert in remotely diagnosing transmission related noises, though. I'm not even particularly great at doing it in person.
Old May 8, 2015 | 06:50 PM
ragingti's Avatar
Drew is correct. It's the throw out bearing/ clutch release bearing. Try pushing the clutch pedal in just a little if the noise changes or goes away its time to pull the transmission. Throw a clutch in there while you're at it.
Old May 9, 2015 | 02:34 PM
apexanimal's Avatar
is this something i should replace when i replace my clutch (at 107k - no abnormal noises)?
Old May 9, 2015 | 03:07 PM
brunny0436's Avatar
sorry to jump in on this, but does the bearing rattle up to 40mph? mine did this and it was the lay shaft bearing which is an apparent common fault with early cars
Old May 9, 2015 | 05:45 PM
ragingti's Avatar
YES. Typically a clutch kit comes with the throw out bearing.
Old May 11, 2015 | 08:47 AM
trinisir's Avatar
omega505
Nov 29, 2017 11:56 AM
Pumpkin
Nov 4, 2017 08:21 AM
TroyGgd3
Oct 26, 2016 08:30 AM
carrier
Jul 1, 2016 07:43 PM
GBR
Jun 12, 2015 08:18 PM
