P0304. 303, 302 & 300 on 08 Fit
Old May 12, 2015 | 06:48 AM
GM2008FIT's Avatar
Hello all. The other day while driving my 125K 2008 Honda Fit would hesitate when if I pressed down on the gas pedal with any authority. Stopped by the local AZ and had them look at the codes. It came up with the above codes.
Now I can see maybe one or two coil packs going bad but three? I replaced the plugs with OEM Iridiums at 90K. There has to be a single point of failure somewhere. Any ideas?
Old May 13, 2015 | 08:14 AM
Carbuff2's Avatar
Was it raining? If you have marginal coils they could all generate codes when the humidity rose.
Could also be loose spark plugs. Might be good to check the plugs and inspect the coils for signs of arcing.
Old May 14, 2015 | 07:53 PM
GM2008FIT's Avatar
Negative on the moisture. I do notice that it starts to happen in the 50-60 mph range.
danielomar91
Oct 11, 2022 04:17 PM
drb53
May 31, 2017 10:40 AM
gavrax
Sep 17, 2016 07:56 PM
Bill_N
May 18, 2015 05:56 PM
