New interior LED bulbs are not turning off
As mentioned in a previous thread. You need a load resistor for the dome and map lights. Some jtechs have them built in the base of the led. A small smd one. Some may not have them. If not this ia the cause of your issue. The gate of the transistor that operates the dome light circuit always leaks a tiny bit of current. Being that leds takes so little power to run and its high resiatance, its able to run off this small leakage voltage dimly. Adding a resistor bleeds this charge off and keeps the led off when the dome light is "off"
the bleed resistor I mentioned will solve this problem. rather than lighting up the LED, the resistor bleeds this small current to ground harmlessly, and no more dim lit lights.
Because the license plate lights are operated more simply via a relay. The Dome/map lights have a fade out feature which is achieved via an SCR and capacitor. The lights are being fed the small leakage current from the SCR (which all of them have some amount of) and the stored charge in the capacitor.
Pretty sure the energy to light up the led is less than what is required to keep your HU preset memory of radio stations for example.
ETA: just checked the map lights and yes it also stays off in the off mode. Again though I prefer my lights to come on when the door is opened, and not manualy done by myself.
Anyone know what LED to get for map light in a 2018'?
These below are too long not allowing the button to click once the cover's installed.
DecalDude
Sep 30, 2012 11:10 PM
whyzor
15
May 8, 2009 04:37 PM
koolkevin1107
152
Feb 2, 2008 12:10 AM
