LED Tail light signal replacement
Old Jul 9, 2015 | 08:27 PM
xancholy's Avatar
Hi,
The 2015 Fit has LED brake lights and regular rear turning light bulb and backup bulbs.
Does anyone have instructions on how to access the turning & backup lights?
The manual seems to have previous model's info.
Brake Light, Taillight, Back-Up Light and Rear Turn Signal Light Bulbs :: Replacing Light Bulbs :: Maintenance :: Honda Fit 2007-2015 Owners Manual :: Second generation (2007–2015) - HoFit.org
Thanks.
Old Jul 9, 2015 | 10:24 PM
andre181's Avatar
Super easy.
Open your hatch.
Remove the 2 bolts that hold the light assembly to the body.
Pull assembly off body.
Turn the plugs 1/4 of a turn to remove.
Replace bulbs.
Reverse process to reassemble.
Old Jul 10, 2015 | 08:25 AM
xancholy's Avatar
Thanks very much Andre!
Old Jul 13, 2015 | 09:43 AM
Bawls's Avatar
Originally Posted by andre181
Super easy.
Open your hatch.
Replace bulbs.
Would I be able to plug in any LED lights into the turn signal and reverse lights?
Old Jul 13, 2015 | 02:59 PM
jhn's Avatar
jhn
I used the following part#:
Rear blinkers: 7440-RHP28-T RED, 2ea
Rear Back-up: 7440-WHP28-T WHITE, 2ea
Front blinkers: 7443-AW60-SA, 2ea
Load resistors: RL-650, 4ea
I purchased them from superbrightled.com. If you ctrl+c / ctrl+v the part#'s in their search box, it will take you right to them.
These are a noticeable improvement over the OE incandescent: Rear blinkers are rated 130 lumens each; 6000K back-up are rated 550 lumens each; front blinkers are rated 192 lumens each.
Front blinkers are 5700K white lights when parking lights are in the on position, then switch to on/off amber when signal/ hazard is used (type A switchbacks), all while consuming a fraction of the power at a claimed 25 times the service life over OE. Hopefully I'll never need to change them for the life of the car.
More info on LED conversions for the entire car can be found here:
Bulb sizes: Fit 2015 - Complete List
Old Jul 13, 2015 | 11:06 PM
xancholy's Avatar
I used these for both my rear turning and backup bulb replacements.
At 1900 lumens, they look just great. Highly recommended.
2pcs 80W 3157 Cree 1960LM Super White LED Turn Signal CAR DRL White Light Bulb | eBay
Old Jul 15, 2015 | 02:27 AM
andre181's Avatar
The bulb is a 7440 for reverse and turn signals.
Use white for reverse (obviously) and for best results, you should use a red for the turn signals. If you use a white for the turn signals, you will end up with pink-ish/orange-ish blinkers.
Old Jul 15, 2015 | 02:29 AM
andre181's Avatar
I used a similar if not identical bulb. I agree that they look great! Nice very bright and very white light.
Old Jul 16, 2015 | 05:35 AM
Kurt Yun-Doyle's Avatar
I have a question about the forward switchback bulb. During daytime driving (with DRLs on), are the switchback parking lamps on at all? If they are, what color are they?
And if I'm reading correctly (with Type As at least), when the headlamps are on at night, the switchbacks are white until you turn on the signal, at which point they blink on/off amber. Correct me if I'm wrong.
Old Jul 16, 2015 | 06:04 AM
andre181's Avatar
The switchback bulbs will only be on if you have your parking lights on unless you rewire your car to run the DRLs through the turn signal/parking lights instead of the main headlights.
You are correct on how they work. They are white when on, and then flash amber once you turn activate the turn signals.
gkitf16
Apr 2, 2012 11:29 PM
xonexlifex
May 18, 2011 03:51 PM
txmatt
Feb 17, 2009 02:46 PM
bsphung117
Nov 14, 2008 12:03 AM
avcm
Oct 4, 2008 04:09 PM
